It is currently Tue Nov 24, 2026 12:37 pm
PostPosted: Sun Jul 18, 2004 4:13 am
Has anyone used the Lokar automatic floor shifter? I guess it bolts to trans, and uses a likage instead of cable...
also need to get a spare /6 904 trans, how do I tell the difference between a /6 model and a small block one? thanks
73 Dart 4dr
70 duster
75 VW bug
ex-88 honda rice rocket
ex-70 cuda 383
PostPosted: Sun Jul 18, 2004 7:51 am
Hey, talk to Chuck (abodynut) and Dennis, they are both in the Chicago area and last I knew, both had a /6 trans or 2 laying around. There was a guy in NW IL (dont know specifically where, but he was parting out a 74 Valiant. Had a post here and on .com about "last call for 74 valiant".
I would then suggest that you drop it by your trans repair buddy (everyone has a buddy like this, right??) and let him go thru it before you put it in the car to be sure you wont have to pull the trans twice.
 Post subject: a904 trans
PostPosted: Mon Jul 19, 2004 3:52 am
thanks Volaredon, actually dennis was giving away a 904 back a few months, but Charles needed one and i told dennis to give it him instead..the guy with the 74 valiant, I think he already junked it at end of June...But I really want to know what is the physical difference between a /6 and small block tran, is it the starter position?, and I am sure bolt pattern is not the same...incase I see one in the junkyard, how do I tell?thanks.....Jerry
73 Dart 4dr
70 duster
75 VW bug
ex-70 cuda 383
