| Lokar shifter, /6 a904 bellhousing https://slantsix.org/forum/viewtopic.php?t=9840 |
| Author: | chi/6er [ Sun Jul 18, 2004 4:13 am ] |
| Post subject: | Lokar shifter, /6 a904 bellhousing |
Has anyone used the Lokar automatic floor shifter? I guess it bolts to trans, and uses a likage instead of cable... also need to get a spare /6 904 trans, how do I tell the difference between a /6 model and a small block one? thanks |
| Author: | volaredon [ Sun Jul 18, 2004 7:51 am ] |
Hey, talk to Chuck (abodynut) and Dennis, they are both in the Chicago area and last I knew, both had a /6 trans or 2 laying around. There was a guy in NW IL (dont know specifically where, but he was parting out a 74 Valiant. Had a post here and on .com about "last call for 74 valiant". I would then suggest that you drop it by your trans repair buddy (everyone has a buddy like this, right??) and let him go thru it before you put it in the car to be sure you wont have to pull the trans twice. |
| Author: | chi/6er [ Mon Jul 19, 2004 3:52 am ] |
| Post subject: | a904 trans |
thanks Volaredon, actually dennis was giving away a 904 back a few months, but Charles needed one and i told dennis to give it him instead..the guy with the 74 valiant, I think he already junked it at end of June...But I really want to know what is the physical difference between a /6 and small block tran, is it the starter position?, and I am sure bolt pattern is not the same...incase I see one in the junkyard, how do I tell?thanks.....Jerry |
