It is currently Tue May 19, 2026 11:15 pm
 Post subject: 727 shifting pattern?
PostPosted: Sun Apr 02, 2006 3:34 pm
I know this may sound strange, but here goes...
It's been a long, long time since I messed with this tranny and I forget where the gears are when I shift at the tranny?
I thought all the way to the rear was Park, but I am not sure now?
Later,
D
PostPosted: Wed Apr 05, 2006 3:08 pm
The gears are always inside the transmission case. Unless something breaks really, really badly. :D
Later,
D
Are you talking about the position of the lever that sticks out of the transmission case, or something else?
PostPosted: Thu Apr 06, 2006 9:12 am
So that's where all them round bumpy things go!!
Thanks!!
Yes, I was refering to the position of the shift lever. I know that it is fully to the rear in park now. I climbed under and started shifting it and checking the driveline. Park - to the rear!
D
Now I need another shift cable - the one I have turned out to have the top inch or so bent and it justs bends inside the shifter housing and doesn't move the shift lever back into park.
