It is currently Wed May 20, 2026 5:40 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
 Post subject: Syntetic in slant6
PostPosted: Mon Aug 13, 2001 6:02 pm
Hello! I'll be glad to know, what modidications I need to do to shift my 225 for syntetic oil?
Thank you!
valiant@comtv.ru
 Post subject: Re: Syntetic in slant6
PostPosted: Mon Aug 13, 2001 6:49 pm
: Hello! I'll be glad to know, what modidications
: I need to do to shift my 225 for syntetic
: oil?
: Thank you!
a) goto parts store
b) buy synthetic oil
c) pure in to slantsix.
done, just like any other motor. And once you start using it you dont want to switch back or mix with normal oil.
cralt@hackme.dhs.org
PostPosted: Mon Aug 13, 2001 8:39 pm
: a) goto parts store
: b) buy synthetic oil
: c) pure in to slantsix.
: done, just like any other motor. And once you
: start using it you dont want to switch back
: or mix with normal oil.
Yup, do all of the above and include a new filter...done! ;-)
 Post subject: Is it good for slants?
PostPosted: Tue Aug 14, 2001 9:27 am
Should I be using synthetic? I'd like to protect my new engine as best as possible.
PostPosted: Tue Aug 14, 2001 12:33 pm
: Should I be using synthetic?
Yes. Any engine that doesn't leak or burn oil should use synthetic.
I've used Mobil 1 in my turbo Duster since I bought it new. I change oil and filter every 5000 miles. At 100,000 miles I pulled the head, and could still see the honing marks in the cylinders. I'm a believer, and even use it in my lawn mower. The engine is much cleaner than engines I've seen using conventional oils. The inside of the valve cover and the valve train aren't coated with blank gunk.
Other synthetics may be just as good. I've never seen any comparison other than some propaganda from some of the companies.
dwordinger@earthlink.net
PostPosted: Tue Aug 14, 2001 3:49 pm
: Should I be using synthetic? I'd like to
: protect my new engine as best as possible.
You should run conventional oil in the engine until it is broken in (at least 500 miles). If you run synthetic right from the start, the engine won't wear enough to break in until much later.
--GH
GHoosdum@yahoo.com
