It is currently Mon Nov 23, 2026 7:14 pm
PostPosted: Thu Apr 27, 2006 7:20 am
Tried a vacuum gauge yet to see if you have a leak?
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Thu Apr 27, 2006 7:51 am
Nope — don't own one, although it's on my list of "tools I want".
VM
 Post subject: Update:
PostPosted: Sun Apr 30, 2006 8:09 am
I adjusted the valves Friday night — no change.
Had Autozone check the charging system — checked out.
I've raised the idle a little more, so it doesn't try to die at stoplights. Guess I'll just plan on changing u-joints frequently until I can save up for a carb rebuild. Again, who's considered a "good" carb rebuilder?
VM
PostPosted: Sun Apr 30, 2006 5:18 pm
Hellooooo... is there anybody out there...?
VM
PostPosted: Sun Apr 30, 2006 5:31 pm
Yeah, we are still here.
Why don't you try rebuilding the carb yourself. We are here to help, and there is only one way to learn. This is how I learned. I had to go back into after I put it on the truck but I learned a valuable lesson. Measure twice install once.
82 D150-225/727
PostPosted: Mon May 01, 2006 9:22 am
Because I've tried it before, and despite an "exploded view" in the kit, I was overwhelmed by the complexity and the number of tiny parts. It comes down to the fact that, unlike an engine or a brake system, I really don't understand how a carb does what it does, only what it does, so I don't know what all of the little parts inside are or what they do. And while professional assembly-line rebuilder might be really bad, they STILL know a lot more about carbs than I do. I don't even know what to look for as far as problems, other than chunks of crap and bad gaskets.
If I ever get enough courage, one day I guess I'll buy the Carter Manual and try again. But for now, I'm content to leave carburetors to the pros, along with transmissions, alignments, tire installation, exhaust work and anything that requires welding (although I try to do everything else.).
Wanna rebuild it for me?
VM
PostPosted: Fri May 05, 2006 9:56 am
If you need your carb rebuilt send me your info and I do it for you. I did my first rebuild and took it to my friend to check(I couldnt pay the going price to have him do it :shock: ) he checked it out for 25 bucks and was impressed. so send me your old core and rebuild kit and I'll take care of it for you. Ill even tune it on my car. I know how much it sucks to not have money or the knowledge to do something. Send me a pm with your info. BTW I just did this this weekend.
