It is currently Sun May 10, 2026 2:50 am
PostPosted: Fri May 05, 2006 4:18 am
I was looking at the chassis book for my '72 Duster and it recommends 0.87" diam. for a 360 cu in (which is what is going back in). The original torsion bars on my Duster are for a Slant Six. Should I go back with the recommended 0.87" or go to something larger. I like the feeling of a solid ride, but not get bounced around.
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Fri May 05, 2006 7:39 am
I've been extremely pleased both times I've replaced the slant-6 torsion bars (stamped 886 and 887 or 622 and 623) with HD V8 torsion bars (stamped 892 and 893). Much more controlled, less jiggly ride without undue harshness.
 Post subject: Yep...
PostPosted: Fri May 05, 2006 9:14 am
As much as I like the std. 73-76 bars (890-891), I'll soon be switchiing to a set of 892-893's I have stuffed away....
If you are junkyard savvy and can find a model that hasn't been front ended...any 1973-1976 Valiant/Dart with a 318 and A/C will have these bars also...
PostPosted: Fri May 05, 2006 10:19 am
Car Model: 1962 Lancer 770
Ben, what kind of LCA/UCA bushings did you put in when you did it?
I think you'd be happy with .87 or .89 tbars for that setup assuming you didn't use poly and have good shocks. I rode in a 65 cuda with a 360 and .87 bars, and the main problem was the jarring from the poly LCA/UCA bushings. You may want a little stiffer too if you're not running a front bar.
