It is currently Sun May 10, 2026 5:50 am
 Post subject: my 7 1/4
PostPosted: Tue Apr 25, 2006 7:38 pm
hi i have a 7 1/4 rear end and i was wondering if it would stand up to a 300 hp slant six? and i was doing burn outs and both wheels always spun is that a posi?
yo yo i be bill
PostPosted: Tue Apr 25, 2006 7:51 pm
Not always, I'd gotten a 7 1/4 to spin both at the same time and I new it was an open diff. If your planning on making 300hp you should step up to an 8 1/4 at least.
70 Dart, 360, 727
PostPosted: Tue Apr 25, 2006 10:12 pm
oh i see can a posi still spin only one tire once in a while too? and will it handel 250 hp then
yo yo i be bill
PostPosted: Tue Apr 25, 2006 11:18 pm
It will not spin one tire, if it is working corectly.
It can handle 250 hp IF it is a sure grip, and if it has been put together properly, and not worn out. Only with an auto, not a stick. It will not live with shock loading.
PostPosted: Wed Apr 26, 2006 7:16 am
Try to find an 8 1/4 rear, they are pretty easy to find. A good 8 1/4 can withstand a hot slant no problem. I have seen posi 8 1/4 survive behind 383's before.
82 D150-225/727
02 Dakota-3.9/5 speed
 Post subject: 300hp
PostPosted: Mon May 08, 2006 8:05 am
wow how do you make a 300hp six ??? :shock:
'67 Dart 225 Super Six
 Post subject: Re: 300hp
PostPosted: Mon May 08, 2006 8:52 am
Mine on the bottle has made 370. :shock:
PostPosted: Mon May 08, 2006 11:53 am
Just read the posts, on this forum, and ask the right questions. It's actually fairly easy, with power adders, but can be done, normally aspired, also. My 170 makes in the upper 200hp range, on N2O.
PostPosted: Mon May 08, 2006 1:31 pm
wow how do you make a 300hp six ??? post by terryx:::
Id agree with Charlie on his comment here. You can get an easy 300hp out of a slant by concentrating on the right combination of parts- Like any engine. Id focus on a very nice cylinder head- porting and bigger valves.]
The cylinder head is the key and is where you gonna make your power.
:D
As far as the 7.25 goes I doubt it could handle 300hp unless it was a sure-grip. I seen Charrlie' thrashin that cuda in the 2002 slant 6 shootout here in Wilkesboro and he was laying down in the 8.20's (IIRC)with his 7.25 sure grip rear on the slicks. They are fairly light rears but good luck finding the sure-grip 7.25- Scarce to say the least. I've seen 2 - Including
the one Im building for my duster! An 8.25 sure grip would be a good idea
though. Building one of those for the '66 cuda bracket car...in progress and will be for quite a while. Good luck with your project!
