It is currently Tue May 19, 2026 8:38 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: Fri Aug 31, 2001 8:12 am
: I would guess it's only a finished manifold
: with throttle discs and shafts in place. No
: injectors, linkage, pump, lines, fuel block
: etc. That's a lot of money for something
: that can be faked out of other stuff. I'll
: bet that a clever person could take a piece
: of 1/2" aluminum plate like a manifold
: gasket, weld 1-3/4" ID 2" OD
: aluminum tubes to it at an angle, and have
: the throttle shaft holes drilled through
: end-to-end in 1 shot by a gunsmith.
: Individual throttle discs & shafts can
: be had from Holley, Carb Shop, BG, etc.
: That's most of the work if you're going for
: EFI, and parts should be less than $150. If
: you did 20 pieces, they might run $300 -
: 400. finished.
1200 bucks? whoa ...you can get a programmable fuelinjection to a turbo car with that....ok the hillborn has the looks, but it is still huge sum of money for that piece only...i think its not tha easy to find people that will pay it...its not the best bang for the buck piece?
http://homepage.mac.com/jyrie
jyri.eramaa@jwt.fi
PostPosted: Fri Aug 31, 2001 3:29 pm
I can make one for about 400$ just the intake and use a mustang throtle body because they are every where.
andrew wagner
: 1200 bucks? whoa ...you can get a programmable
: fuelinjection to a turbo car with that....ok
: the hillborn has the looks, but it is still
: huge sum of money for that piece only...i
: think its not tha easy to find people that
: will pay it...its not the best bang for the
: buck piece?
