It is currently Sun May 10, 2026 5:05 am
 Post subject: Rear wheel bearings?
PostPosted: Tue May 23, 2006 7:37 am
HI all
OK I have got some noise coming from the rear of my 67 dart.
I'm suspecting the rear wheel bearings.
I took the wheels off to have a look
the Pasinger side is leaking oil.
But the drivers side will move in and out about a 1/4 inch
IS This NORMAL ? ? ? ?
or is somthing seriously worn/broaken.
advice/ideas appreciated
Terry
:wink:
'67 Dart 225 Super Six
PostPosted: Tue May 23, 2006 9:41 am
That's bad no matter what axle is under the car. Chances are it's a 7 1/4 and the driver's side bearing is bad. I say pull both axles and replace the bearings.
PostPosted: Wed May 24, 2006 6:39 am
the older 7-1/4s like yours had tapered bearings pressed onto the axle. Haven't seen one in a while, but I believe that theyre like the 8-3/4 with the adjuster on one side for endplay. If youre leaking fluid theyre gonna have to come out anyway because the seal is on the axle behind the bearing which will get ruined pressing it off to change the seal. Did that one also have a seal insde the axle tube?? I don't remember. some had 2 seals on each side.
PostPosted: Wed May 24, 2006 6:36 pm
My 7 1/4" rear in my '68 Dart had caged ball bearings. I learned this some years ago while driving and having a catastrophic bearing failure on the highway. What year was the switch over?
'68 Dodge Dart 4dr Sedan
PostPosted: Thu May 25, 2006 6:48 am
was this caged ball bearing pressed onto the axle or in the housing, with the axle retained by C clips?? If the axle flange has holes between the studs for a socket to get in there to reach the flange nuts its not a C clip rear. Is this the orig housing in your 68? I have worked on more late 70s and 80s cars that were all C clip style. (my 90 Dakota even had a C clip 7-1/4 in it; now has an 8-1/4 since my brother in law grenaded the 7-1/4)
Not sure the exact year, but I think it was like 74-75-76 area when they switched. Anyone got a bearing catalog? that would be a way to tell.
PostPosted: Thu May 25, 2006 7:16 pm
Non c-clip. (the rear wheel with axle attached went flying down the road!) The caged ball bearings were pressed onto the axles. I no longer have the rear. After that incident, I went to an 8 3/4" just as a "might as well replace it if I gotta replace it."
