It is currently Fri May 15, 2026 12:46 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
 Post subject: K-members and mounts.
PostPosted: Tue Sep 04, 2001 9:40 pm
Which are better and why? The older style with the biscuit mounts or the newer style with the spool mounts.
drucker@sbcglobal.net
PostPosted: Tue Sep 04, 2001 11:11 pm
: Which are better and why? The older style with
: the biscuit mounts or the newer style with
: the spool mounts.
Spool type, hands down, no brainer.
Spool type mounts last longer, they will contain the engine even when worn-out or broken, they can be stiffened by filling the voids in the rubber and most of all, these make engine "drop-ins" a snap.
If you have a 67 or later A-Body and do lots of engine swaps or if you are about to do front end work, swap-over the K-frame to the spool type while you are in there.
PostPosted: Wed Sep 05, 2001 2:25 am
: Spool type, hands down, no brainer.
: Spool type mounts last longer, they will
: contain the engine even when worn-out or
: broken, they can be stiffened by filling the
: voids in the rubber and most of all, these
: make engine "drop-ins" a snap.
: If you have a 67 or later A-Body and do lots of
: engine swaps or if you are about to do front
: end work, swap-over the K-frame to the spool
: type while you are in there.
: DD
Okay, thanks for the info. But will I have to use the idler arm and associated steering linkage from the donor vehicle? Thanks again for sharing your knowledge.
PostPosted: Wed Sep 05, 2001 9:23 pm
: Okay, thanks for the info. But will I have to
: use the idler arm and associated steering
: linkage from the donor vehicle? Thanks again
: for sharing your knowledge.
The spool K's use the "through bolt" type idler arm. (68-76) there are a few different center links tat all swap in, I used the 68-72 type because it has the deepest "U" and gets me the most oil pan clearance.
PostPosted: Wed Sep 05, 2001 9:29 pm
: DD
Here's another, related question: does anybody refurbish these (a-la Damper Dudes)? I was shopping for new spool types awhile ago and even the ones bearing the names of supposedly-reputable American companies were "hecho en Mejico" and very poorly made.
I found one Borg Warner (@ an independent auto parts store) which had obviously been on the shelf for years---the difference in quality was striking. Any American companies still making good ones? Thanks.
---Red
Torr66@aol.com
