It is currently Sat Oct 10, 2026 7:43 pm
Post new topic  Reply to topic  [ 88 posts ]  Go to page Previous 1 2 3 4 5 6
PostPosted: Fri Mar 03, 2006 4:22 pm
http://www.primediabackissues.com/Merch ... ry_Code=MM The one you want is third from the bottom as of time of this message, code MM0602
PostPosted: Tue Mar 07, 2006 5:09 pm
Any idea what this EFI set-up would be worth?
Would there be a bigger gain from using a roller cam and spending the money there?
From what I can tell they didn't rejet the carby for optimum performance, they just say that they bedded in the cam, set the timing and went for it. They mention that the carby was running lean but make no mention of what they did, if anything, to correct the situation.
Would it be unfair of me to suggest they didn't optimise the carby so that the HP figures between the carby and the EFI were different enough to make the EFI changeover look like a worthwhile investment?
PostPosted: Wed Mar 08, 2006 5:06 am
correct, and as sick6 said, they switched manifolds
still not a bad buildup though, just slightly misleading
-dave
what part of "illegal" is so confusing???
 Post subject: What carb??
PostPosted: Sun Mar 12, 2006 9:57 am
Did they use a 500cfm edelbrock carb on this motor?? I believe along with
most people on here that they would have found even more "clarifying"
results with taking the time to dial in the carb. This appeals to me in the fact that the carb fits my budget much better than custom efi...
 Post subject: Re: What carb??
PostPosted: Thu Mar 16, 2006 5:35 pm
Okay ... The carb was a 650, and it was dialed in before it made the 300 HP. It was not running lean for the final carbureted pull. But in order to get the A/F ratio correct on the high end, it was too fat on the low end. It would take more time to get it all right than we felt was neccessary since we were only looking for the high end number. The manifolds were different, but only because the Clifford was easier to convert to EFI.
Rich Nedbal
PostPosted: Thu Mar 16, 2006 6:21 pm
OK Rich, thanks for clearing that up.
What would the EFI set-up cost?
 Post subject: carb
PostPosted: Thu Mar 16, 2006 6:30 pm
This would have been the thunderseries right??
Thanks Rich.. :D
PostPosted: Thu Mar 16, 2006 7:03 pm
Rich Nedbal
Actually why didn't you run the carb on the clifford manifold with the injectors in place to stop vacuum leaks but with the ECU unplugged? Then you could have bolted the TB in place, hooked up the TPS, and done back to back testing.
Just a thought.
PostPosted: Fri Mar 17, 2006 6:49 am
Rich Nedbal
Just a thought.
Good question! I wondered why I did that myself. :oops: I guess I did it that way because that was the manifold/carb from his previous engine - and I knew it was going to take a fair amount of time getting that setup dialed. I also expected that it was going to take at least another day or two to get all the electronics working so we just bolted up what would work quickly. But looking back, I should have started with the EFI manifold and stayed with it. Maybe next time :D
Rich Nedbal
PostPosted: Fri Mar 17, 2006 6:55 am
A "rough" breakdown of typical EFI costs is on the web site under EFI.
http://www.moparengineswest.com
But any FAST type system runs around $3K+. And you have to add in the cost of the EFI fuel delivery and return system.
Rich Nedbal
PostPosted: Fri Mar 17, 2006 3:22 pm
Rich,
Just wanted to say thanks for your work here. Finally got the issue, ordered from their backissues, and the article looks great. Hope I get to see Romeo run it sometime and/or meet you in person. Can't make Vegas this year, but maybe next...
PostPosted: Fri May 26, 2006 12:09 pm
Anyone know what happend to these folks? I called them and got a message saying our offices will be closed from May till January 29th...
PostPosted: Wed May 31, 2006 5:20 pm
Their website says they moved and have new phone numbers. Maybe that's why they didn't answer.
Figured I would chime in as I ended up on the website and came across this tidbit of info.
http://moparengineswest.com/
'15 Chrysler 200S V6
'74 Duster 360, factory 4 speed car
Users browsing this forum: Plymouth_Ruster and 20 guests
