It is currently Tue Nov 24, 2026 8:58 pm
 Post subject: Crankshaft bolt
PostPosted: Sat Jun 03, 2006 8:39 am
Is there a crankshaft bolt that holds on the harmonic balancer or is it just a press fit? thanks...........matt
PostPosted: Sat Jun 03, 2006 8:56 am
Press fit
63 Valiant 200 Signet Convertible 170/
63 Dart, 225/
68 A100 Pick-up 225/
2006 Mitsu Raider Quad Cab (Dakota) Mopar 4.7L
1992 Dodge Stealth RT (My Mid-Lifer) 3.0L 24V
PostPosted: Sat Jun 03, 2006 11:13 am
But it's also threaded; you'll need the bolt to press it on anyway, might as well leave it so you can use it to rotate the engine.
PostPosted: Sun Jun 04, 2006 12:36 am
Its a 3/4 inch x 16 threads per inch bolt. Have fun finding one. I snagged out of a 383 for mine.
PostPosted: Sun Jun 04, 2006 4:58 am
yeah, not your local hardware store item. perhaps one of the mopar performance bolts would work. or try a bolt and screw supply house.
-james
PostPosted: Sun Jun 04, 2006 5:12 am
Some Slants had one from the factory, some didn't. :shock:
PostPosted: Sun Jun 04, 2006 5:57 pm
Hello all.
I like to put the bolt in cause I usually work alone and the bolt makes it easier for me to turn the crank when doing static timing (before starter, etc. are in). A super good bolt store here sells them for about 1.50. I like Grade 8, cause one of my FSM's says 210 ft. lbs torque, while another says 135 ft lbs. Both mopar pubs too. I would be glad to give anyone the phone number of the store if interested. I redid every bolt in my truck with stainless from them, and used chrome on the engine compartment.
rock
'64d100
PostPosted: Sun Jun 04, 2006 6:58 pm
Car Model: 63 Dart 81 D150
IIRC it is the same as a LA smallblock bolt.
if so, it would be easy to find in a J-yard for used.
I think ARP sells new ones that should handle anything a slant can put out
