It is currently Sun May 17, 2026 6:51 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: Tue Sep 11, 2001 11:10 am
I finally got my 65 valiant v100 upgraded to a super six 2 barrel setup and it turns on and it idles. I haven't driven it yet though. When I try to accelerate, it bogs. Too much gas? Jets too big? If I accelereate the engine slow enough, it will rev up but only to a ceratin point, then it wants to turn off. Any ideas?
Orionsax7@cs.com
PostPosted: Fri Oct 05, 2001 10:07 am
: I finally got my 65 valiant v100 upgraded to a
: super six 2 barrel setup and it turns on and
: it idles. I haven't driven it yet though.
: When I try to accelerate, it bogs. Too much
: gas? Jets too big? If I accelereate the
: engine slow enough, it will rev up but only
: to a ceratin point, then it wants to turn
: off. Any ideas?
I upgraded my '63 to a Super Six with no problems, but I had taken the carb to a shop and had a professional rebuild done on it.
I would first check to see that you are getting sufficient gas from the accelerator pump for the acceleration problem.
For the second problem, I have seen a stall-out problem with a couple of old 1 bbl carbs that were shot. It could be a low float adjustment. I would guess that a full rebuild is in order.
Chuck
webmaster@omnipages.com
