It is currently Sun Nov 22, 2026 11:16 pm
PostPosted: Mon Jun 12, 2006 8:41 am
I just took my lower control arm bushings out. Boy that was hard!!!!!!!!!!
I have the inner bushings still stuck on the LCA shaft. Anybody know how to get them off - the easy way. I know the hard way. :wink:
And is it just as hard to press the new ones in? If so, could I get them pressed in at the auto parts store?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Mon Jun 12, 2006 9:22 am
The easy way is to take the LCA and new bushing to your favorite machine shop and pay them $10-15 each to remove the old bushing and press in the new one.
One of the best $20 I ever spent!
VM
PostPosted: Mon Jun 12, 2006 4:52 pm
if you have a local surplus store see if they have a large 1 3/8 NF12 tap--- tap that puppy in & press out the outer shell-- works for me--- others with welders-- use some thick washers weld them around the edge & press them out--- good -- luck--
The local shop here wanted $100 for this procedure so I found this in my 62 FSM--- plus I have access to a shop press--- good luck
