It is currently Sat Jul 18, 2026 10:07 am
Post new topic  Reply to topic  [ 30 posts ]  Go to page Previous 1 2
PostPosted: Tue Jun 06, 2006 11:36 am
Hi Lou, What carb were you using with that combo in the green dart??
Also is it a long rod engine or is it just a 225 w/225 rods?? Did you shave
the block and head or just head?? Think that I could get away with 3000 stall?? Thanx!
PostPosted: Tue Jun 06, 2006 1:07 pm
I used several carbs - hly 600 4bbl, Edel 600 4bbl, 670 2bbl TBI w/hly and then megasquirt computer... Best 1/4 mile was with tuned Edel 600 4bbl, but that was with fresher motor.
225 rods and stock replacement cast MP (Fed Mog??) 0.060" pistons. No block shaving, lots of head shaving.
As I said, I ran low 14s with a 3000-3200 stall converter, so yes it should work for you.
PostPosted: Tue Jun 06, 2006 1:09 pm
225 rods and stock replacement cast MP (Fed Mog??) 0.060" pistons. No block shaving, lots of head shaving. (by Dart270)
.100 or more on the head?>? stock length pushrods???
PostPosted: Tue Jun 06, 2006 2:35 pm
0.080" on the intake side, 0.180" on the plug side. Stock pushrods BARELY work, but I bent/broke a few and didn't like the geometry, so got some custom ones about 0.2" shorter (using 0.1" longer SBC valves too).
PostPosted: Tue Jun 06, 2006 3:11 pm
(post by Dart270)
.080 shave on the intake side?? I've havent heard of that before...(any benefits to that?)
Anything else to be noted on a lot of head shaving like that or anything to watch out for??
Didnt know you could take .180 off of the head either :shock: !!!
PostPosted: Tue Jun 06, 2006 4:06 pm
Lou had his head angle milled. It was cut .080" on the manifold side of the head and .180" on the plug side. I'm wondering if his intake manifold is noticeably tilted?
PostPosted: Tue Jun 06, 2006 6:28 pm
http://video.yahoo.com/video/play?vid=732fdab5299634ad4bd9d00edcea8467.485314
Also the 2bbl is a poor choice. (post by Joshie225)
It'll need more when I get to that point but it works pretty good now!
A 2bbl may not be the best choice but it's far from a poor choice. The #4412 universal 500cfm 2300 is only 15cfm less than the 390 4bbl (rated at the same hg).
Advantages of a 2300 Holley vs 4150/4160...
only 2 jets to change
1 float to set
1 float to stick and flood
1 bowl to leak
1 less fuel line or transfer tube to leak
jets are always covered during accleration if mounted like a OEM BBD
Disadvantages...
15cfm less
not as tuneable for fuel distribution due to 2 bores available, vs 4 bores, to stagger jet
Slant Cecil
PostPosted: Tue Jun 06, 2006 6:49 pm
If you really stare, you might see an angle, but I can't remember if I've actually seen it. I did the angle mill using advice from Meril Bruner, passed on to me in 1992. Couldn't tell you if it helps or not, but I've had no ill effects. Meril did his 0 on the manifold side and 0.200" on the plug side. :shock: You can also angle mill the head bolt bosses on the top of the head.
PostPosted: Sat Jun 10, 2006 12:42 am
Car Model: Valiant V200 225 4dr three on the tree
Meril did his 0 on the manifold side and 0.200" on the plug side. You can also angle mill the head bolt bosses on the top of the head.
Do you know if it is necessary to "correct" the headbolt holes? Considering the angle.
Thanks
Lasse
Signet -66 225
Holley 600 Offy-5270 Dutra Dual,regrind. cam 272 0,420 110, head shaved 0.100 slight.ported
MSD6A
A904
7 1/4 3.23
PostPosted: Sat Jun 10, 2006 6:55 am
I did not angle mill my bolt hole bosses (0.100" differential mill). Could be a problem with a 0.200" differential?? No experience. Meril said he angled them, IIRC.
PostPosted: Sat Jun 10, 2006 11:48 am
1 float to set
1 bowl to leak
Disadvantages...
15cfm less
How about throttle response and fuel economy? Air flows a lot more slowly through the 2bbl's venturis at cruise than the primaries of a 390 4bbl.
BTW, I've never had a float bowl leak on my 390. In fact of all the Holleys I've owned only one had a float bowl leak and it was a 2nd hand 2bbl. I've only had the transfer tube leak once as I got in a hurry and didn't put the 0-ring on the tube itself. My two cases of flooding have been from dirt on the primary needle. I think the main benefit of the 2bbl is one you didn't mention. Cost.
PostPosted: Sun Jun 11, 2006 9:23 am
PostPosted: Sun Jun 11, 2006 9:48 am
Re: angle milling. The purpose is to improve the port draft angle, yes?
No.
PostPosted: Sun Jun 11, 2006 6:09 pm
Hyster used to use double washers like that for chain anchor seats. :shock:
PostPosted: Tue Jun 13, 2006 4:27 pm
That was sooo kewl ("no").
