It is currently Sun May 24, 2026 10:45 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 8 posts ]
 Post subject: no power
PostPosted: Sun Sep 30, 2001 6:16 pm
shold the timing marks line up with 0 on the timing chain cover when the timing marks on the cam gears are lined up mine line up with a round tube on the cover don,t know what it is for tryed another cover and dampner was the same thanks for any help
brentmcl@home.com
 Post subject: Re: No "New" Power ?
PostPosted: Mon Oct 01, 2001 9:25 am
: Should the timing marks line up with 0 on the
: timing chain cover when the timing marks on
: the cam gears are lined up? My mark lines up
: with a round tube on the cover don,t know what it is for.
This "tube" is for the factory service "probe" mount point. I would suggest using the earler style cover with the conventional "tab" markings.
As for your new engine set-up not making good power, get us a little more info. like the cam's profile info. (especially the overlap "number")
There is an important relationship between the cam and the stactic compression ratio. This is why you see most performance cams combined with increased stactic compression, the bigger cam "uses-up" some of the new compression.
As noted by others, check the cam's installed position and also check the current cranking compression with a guage. (cranking compression will tend to increase as you advance the cam timing) This added info. will shed some light on your lack of "pep".
Here is a link to one of Lou's posts on this subject:
Cams vs Compression
PostPosted: Mon Oct 01, 2001 6:06 pm
: This "tube" is for the factory
: service "probe" mount point. I
: would suggest using the earler style cover
: with the conventional "tab"
: markings.
: As for your new engine set-up not making good
: power, get us a little more info. like the
: cam's profile info. (especially the overlap
: "number")
: There is an important relationship between the
: cam and the stactic compression ratio. This
: is why you see most performance cams
: combined with increased stactic compression,
: the bigger cam "uses-up" some of
: the new compression.
: As noted by others, check the cam's installed
: position and also check the current cranking
: compression with a guage. (cranking
: compression will tend to increase as you
: advance the cam timing) This added info.
: will shed some light on your lack of
: "pep".
: Here is a link to one of Lou's posts on this
: subject: DD
The cam is a Comcams:
Grind Number: CR6 264S-10
Serial Number: MB3387
Intake Exhaust
Valve Adjustment .010 .012
Gross Valve Lift .440 .440
Duration AT
.020 Tappet Lift 264 264
Valve Timing open close
at .020 INT 24 BTDC 60 ABDC
EXH 60 BBDC 24 ATDC
These specs. are for cam installed at 106 intake center line.
Intake Exhaust
Duration at .50 220 220
Lobe Lift .2933 .2933
Lobe Separation 110
brentmcl@home.com
PostPosted: Mon Oct 01, 2001 7:56 pm
: The cam is a Comcams: Grind Number: CR6 264S-10
: Serial Number: MB3387
: Intake Exhaust
: Valve Adjustment .010 .012
: Gross Valve Lift .440 .440
: Duration AT
: .020 Tappet Lift 264 264
: Valve Timing open close
: at .020 INT 24 BTDC 60 ABDC
: EXH 60 BBDC 24 ATDC
: These specs. are for cam installed at 106
: intake center line.
: Intake Exhaust
: Duration at .50 220 220
: Lobe Lift .2933 .2933
: Lobe Separation 110
i also used that cam in my first slant rebuild and was very unhappy with it. it comes on about 2200 and went flat around 42-4400. pitiful powerband to say the least. i tried it in another motor after that one with ill results again. i can not say enough good things about the 264 isky grind i ran for a while, or the reed cam i have now......chad
beardliz@msn.com
PostPosted: Mon Oct 01, 2001 8:21 pm
: i also used that cam in my first slant rebuild
: and was very unhappy with it. it comes on
: about 2200 and went flat around 42-4400.
: pitiful powerband to say the least. i tried
: it in another motor after that one with ill
: results again. i can not say enough good
: things about the 264 isky grind i ran for a
: while, or the reed cam i have now......chad
I have a Comp cam in my 225 and it runs fine;
lift .440 for both intake and exhaust
4.0 degree overlap
108 degree lobe center
IO 2 BTDC IC 38 ABDC
EVO 38 BBDC EVC 2 ATDC
Intake .010 hot
Exhaust .012 hot
dbjerklund@hotmail.com
PostPosted: Tue Oct 02, 2001 2:40 am
: I have a Comp cam in my 225 and it runs fine;
: lift .440 for both intake and exhaust
: 4.0 degree overlap
: 108 degree lobe center
: IO 2 BTDC IC 38 ABDC
: EVO 38 BBDC EVC 2 ATDC
: Intake .010 hot
: Exhaust .012 hot
needless to say, cams are quite application specific.
beardliz@msn.com
PostPosted: Tue Oct 02, 2001 8:52 am
: needless to say, cams are quite application
: specific.
Just so y'all know, that cam is very close to stock.
madsenl@caltech.edu
PostPosted: Tue Oct 02, 2001 9:47 am
: Intake .010 hot
: Exhaust .012 hot
One tip on these Comp cams, I tend to run them a little looser on the exhaust "lash" and get better results, try .014 to .016 "lash" to see if it runs better.
I have to say that the internet is speeding-up our understanding about the available SL6 cams and what seems to work best.
My "vision" is to someday have enough info. and test data where we can have some great working part combos for others to follow. The "Frog" and "Bow-tie Boys" have had these types of "recipes" for years. (Mopar V8's have them also)
Basically a set compression ratio (pistons), cam (on an established installed centerline), intake, carb. and headers. (Head porting and valve size would also be a big factor for our SL6)
We are seeing a number of people "closing-in" on good part combos so please keep the information flowing.
