It is currently Mon May 11, 2026 7:04 pm
PostPosted: Tue Jul 18, 2006 7:15 pm
So, what are the sounds and symptoms of the overrun clutch going bad in a 904?
I have a bad feeling about my drive home last night.
Greg :shock:
PostPosted: Wed Jul 19, 2006 8:18 am
So, not getting any response, let me tell you what happened, and hopefully, it will ring a bell with somebody. The tranny seems fine as I am getting up to speed or holding a steady speed. If I take my foot off the gas, or hit the brakes ( slowing down in traffic, taking a corner, etc), I am hearing a buzzing or rumbling coming from what I think is the transmission.
So, whatta ya think? Overrunning clutch? It makes sense to me.
PostPosted: Wed Jul 19, 2006 9:21 am
I would spend the time to drop the trans. pan and take a look for signs of trouble. (pieces of metal)
Low fluid or poor fluid flow (plugged filter) can cause a buzzing sound.
In general. a OR clutch problem is hard to spot prior to complete failure.
PostPosted: Wed Jul 19, 2006 9:36 am
I will give that a try. I should replace the filter anyway. It may be the original, given the rest of the maintenance that I have seen.
PostPosted: Sun Jul 23, 2006 11:05 am
I saw a few bright bits of metal in the pan. The magnet test picked up only a few, so I am guessing that most were aluminum. I have refilled the trans, and started it up, cycling through the gears. All is good so far. I will try it out after church today.
Users browsing this forum: volaredon and 7 guests
