It is currently Sat Jun 13, 2026 5:03 pm
 Post subject: pistons
PostPosted: Tue Jul 25, 2006 2:21 pm
I was wondering if there is an after market piston I could use with stock 225 rods or with the 198 rods if I can find a set. I plan to use an isky cam,offy 4 barrel intake, edelbrock carb and an MSD ignition. The head will be ported and polished and have bigger valves. Also what valves would make a good oversized valve. Are there roller rockers for the slant six. Thank you.
1980 D-150
225 cid
PostPosted: Tue Jul 25, 2006 3:11 pm
For Stainless valves:
http://www.sivalves.com/ocdomestic_valvesps_dodge.html
For Roller Rocker Arms:
Cox Brothers:
coxbros66@msn.com
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Tue Jul 25, 2006 7:09 pm
SSRN National Champion
Wo slow down and tell us what you want in your car that was a lot of stuff to throw at us. Is it a street car /street/strip car /cruser car. or a full drag car. Then some solid opining can be done. Thanks Ron Parker :D
It Aint Over Until I Win
PostPosted: Tue Jul 25, 2006 8:58 pm
I was wondering since KB-Silvolite makes hypereutectic 2.2/2.5 pistons how hard would it be for them to adjust the tooling a little to give us a decent hypereutectic piston to work with stock rods? Maybe I should call?
PostPosted: Tue Jul 25, 2006 10:42 pm
and get 0.0" deck..........
PostPosted: Tue Jul 25, 2006 10:43 pm
That would be cool, if they would do it for a reasonable cost. Surely the weight reduction alone would help!
I found some 198 rods and will be using the silvolites for my new engine.
Bill
If ya haven't been there, you just wouldn't understand.....
My friends and I spent a LOT of money in the eighties to get me this way!!!!
PostPosted: Tue Jul 25, 2006 11:41 pm
Well, for my 170 the stock compression distance is fine. We should start calling and see what they'll do for us.
PostPosted: Wed Jul 26, 2006 9:56 am
Sorry Ron.
The truck will be used for street/strip. Mostly street.
Aslo truck will have a stock rearend for now and it also has a stock 904 transmission.
1980 D-150
225 cid
PostPosted: Wed Jul 26, 2006 9:58 am
That's a business, not a hobby. I'd be very surprised if they had a minimum volume of less than 1000 - that's 167 engines...
PostPosted: Wed Jul 26, 2006 12:09 pm
I don't think it would work on a 225 rod. They would have to move the pin hole over .325" down in the piston. :shock:
PostPosted: Wed Jul 26, 2006 1:01 pm
I have a 1980 D-150 Truck and have done some performance mods on it (see text below). There is a vast improvement between the stock 225 and my new performance 225, but the truck is still HEAVY compared to an A body. My next performance 225 will be in a '65 Valiant or the like. I can't wait to unleash a performance Slant Six in a light bodied car. What a HOOT that will be. :twisted:
bwhitejr
0.090 Shaved Head
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 3 guests
