It is currently Fri May 22, 2026 9:14 am
PostPosted: Thu Nov 08, 2001 11:55 am
Which if any of the disk brake parts from a Volaré / Aspen will fit late model Darts and Valiants? I think the rotor and caliper is the same. What about the spindles and caliper mounts?
cfield@ll.net
PostPosted: Thu Nov 08, 2001 12:07 pm
: Which if any of the disk brake parts from a
: Volaré / Aspen will fit late model Darts and
: Valiants? I think the rotor and caliper is
: the same. What about the spindles and
: caliper mounts?
You might check over at slantsix.com I had posted all the part numbers from the 1976 parts catalog on what can be used for a F to A body front disk brake swap...
res0aus2@verizon.net
PostPosted: Thu Nov 29, 2001 1:19 pm
: You might check over at slantsix.com I had
: posted all the part numbers from the 1976
: parts catalog on what can be used for a F to
: A body front disk brake swap...
: -D.Idiot
The Spindles are not the same, though these parts are INTERCHANGEABLE (that's the key word) with the 73-'76 A-body setup
Caliper Adapters
Calipers
Rotors (Same)
Wheel Bearings
Seals
Dust Cap
The F-body spindles are 3/8" taller andw will change your suspension geomotry.
goldduster318@yahoo.com
PostPosted: Fri Nov 30, 2001 8:00 am
: The Spindles are not the same, though these
: parts are INTERCHANGEABLE (that's the key
: word) with the 73-'76 A-body setup
Check out <A HREF="http://www.moparts.com">http://www.moparts.com</A> . They have a couple of very long threads on this topic. A lot of people checked in on this, including some heavy weight Mopar mag writers. Very interesting reading.
klesteb@aol.com
