It is currently Thu Nov 26, 2026 8:19 pm
 Post subject: Redline?
PostPosted: Sun Aug 06, 2006 11:42 am
On a 225 what is the redline or rpm max that you dont want to exceed?
i have one in my boat and im not sure.... i can go a little past 4000 rpm is this to much? or can i go further?
PostPosted: Sun Aug 06, 2006 12:41 pm
well keep going until it flys apart, then when you put a new motor in it, don't go that far and you should be fine.
Bone stock 1966 dodge dart, powered by a 145hp 225
PostPosted: Sun Aug 06, 2006 1:30 pm
A stock 1bbl 225 will run out of breath before redline.............
A little past 4000 is no problem.
PostPosted: Sun Aug 06, 2006 4:14 pm
And, again, a complete waste of my time.
PostPosted: Sun Aug 06, 2006 4:30 pm
its a stock 225 1 bl can i go to 5000 rpm?
in a boat
PostPosted: Sun Aug 06, 2006 4:43 pm
in a boat
You'll never get there if the prop is properly matched to the engine and hull combination.
PostPosted: Sun Aug 06, 2006 10:26 pm
Stock 225 1 bbl is sucking wind at 4200. :shock:
PostPosted: Mon Aug 07, 2006 6:07 am
my slant when it had the 1 barrel was useless at 4,000 RPM.
PostPosted: Tue Aug 08, 2006 8:09 am
i can rap mine out to 5000 but its pretty much useless past 4250,just knowing i can do highway speeds in first is kinda cool though(2.76 rear gear) :D :twisted:
1975 Plymouth Duster,225/6 2bbl. and duels, 904, 7 1/4
1986 Dodge Charger Shelby, 2.2 Turbo I, A525
PostPosted: Tue Aug 08, 2006 5:44 pm
SSRN National Champion
In a 2400 lb drag car my stock engine would pull to about 4400 rpm and quit to much drag and friction. Never had a problem after 5000 rounds. of drag racing. Thanks Ron Parker :D
It Aint Over Until I Win
PostPosted: Fri Aug 11, 2006 5:10 am
PANIC........clarify??? "a complete waste of time" GRT
PostPosted: Fri Aug 11, 2006 5:25 am
It is a complete waste of time to worry about what he means by that. :lol:
Sam
PostPosted: Fri Aug 11, 2006 5:31 am
It is as Sam said.
Panic likes to edit his posts after the fact and than the thread does make much sence.
PostPosted: Fri Aug 11, 2006 7:52 am
Yes, it's that annoying tendency to remove material that answered the question, only to see...
the same question asked again.
If you're not going to read it, I won't answer it.
PostPosted: Fri Aug 11, 2006 3:21 pm
Panic
You're obviously a bright dude. Some of your information can be over the heads of some, but to others its good information. Editing your text to remove it is a bit selfish to the ones that do understand.
No body likes it when you take the ball home (if this were a game). Leave the ball so we can kick it around.
Users browsing this forum: Amazon [Bot] and 8 guests
