It is currently Tue May 12, 2026 11:26 am
 Post subject: 7/8 or 3/4 rear sway?
PostPosted: Mon Aug 21, 2006 7:49 am
73 Swinger. I finally installed my 1 1/8 Hellwig front sway bar yesterday. What a difference in handling! But, I can feel the rear pushing the front end (is this oversteer?), so now I want to install a rear sway bar. I have new 5-leaf springs on the back already, and new KYBs all the way around.
Should I get a 3/4 or a 7/8? For some reason the 7/8 is $20 cheaper.
A couple of things on the Hellwig. First of all, the sway bar went through my K frame and fit great, except the attachment plate for the LCA isn't great (and Hellwig gave me bolts, the ones from the sway bar to the LCA, were way too long, I had to go out and buy the proper length). Does anybody have a picture of a factory sway bar tab for the LCA? I may end up welding something better than the Hellwig setup.
PostPosted: Mon Aug 21, 2006 7:57 am
If you have oversteer a rear bar will make it worse. The 5 leafs and KYBs are probably all you need. I would drive it for a while and get used to it and see if you really need the rear.
PostPosted: Mon Aug 21, 2006 11:05 am
Thanks, I just took it for the one test drive about 5 miles (on a curvy road) after I installed the front sway. I will drive it a while to get a better feel.
PostPosted: Mon Aug 21, 2006 6:57 pm
A 1/2" sway bar is likely enough for your car and 5/8" is probably plenty. 3/4" and 7/8" are almost always too much and will induce significant oversteer.
PostPosted: Tue Aug 22, 2006 1:17 am
I'll agree that 7/8" is too much, but I find 3/4" perfect..........
BTW, that's with stock torsion bars (no doubt smallest available) and stock 4-leaf rear.......
It all depends on you spring stiffness............
PostPosted: Tue Aug 22, 2006 4:20 am
Online
I have tried a 3/4" rear bar on two Darts with fairly stiff rear springs, and it makes it way too loose (oversteer). Spend your money on something else fun. :D
PostPosted: Tue Aug 22, 2006 7:39 am
It seems unanimous. I will drive it a while and get the bumblebee stripe instead. Thank guys!
