It is currently Fri Jun 05, 2026 8:30 pm
PostPosted: Sat Sep 02, 2006 9:45 am
i was curious if u guys know if my 82 dippy might be wired for the oil pressure guage that is installed on most grand furys? ive looked in my car and couldnt find the connector so im guessing that was a after market install?
2003 Ford Escape
1993 Mustang Cobra *stock*
1991 Honda Civic boosted ls/vtec *toy*
1982 Dodge Diplomat *daily driver*
PostPosted: Sat Sep 02, 2006 4:30 pm
In order to install a pressure gauge, you need a sender capable of driving a gauge. Factory P/N on that sender is 2427 237. Once you've got that installed in place of the original "red light only" sender, you're pretty much all set.
PostPosted: Mon Sep 04, 2006 8:03 pm
Dan you still get these parts through Mopar? My local Chrysler dealer said they couldn't get these anymore :roll: . I want to get rid of the idiot light on my Duster also. I don't trust it.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Mon Sep 04, 2006 8:39 pm
NAPA Echlin OP6670 is the late-type gauge-and-light sender. Has two terminals: One is on/off for the light, and the other is variable for a gauge. You can get the matching socket off a '90-up "anything" at the wrecking yard.
PostPosted: Mon Sep 04, 2006 8:42 pm
Hey!.....thats MY phone #!
PostPosted: Mon Sep 04, 2006 8:47 pm
Oh? It's not BEechwood 4-5789?
PostPosted: Mon Sep 04, 2006 9:08 pm
Hey Dan, I am having one of those Duh-uh moments Could you be a little more specific in what cars I could pull the connector off of?
82 D150-225/727
PostPosted: Tue Sep 05, 2006 5:47 am
can i ask what a "red light only" is? lol im clueless here
2003 Ford Escape
PostPosted: Tue Sep 05, 2006 6:07 am
AKA "idiot light" pressure switch. An oil pressure switch (normally closed, I think) that turns off the red "Oil" light on the dash when oil pressure comes up to some set level.
To run a gauge, you need a sender that changes over the range of pressure.
To run a gauge and an light, you need both types plumbed into the oil system.
PostPosted: Tue Sep 05, 2006 8:19 am
Well, yeah, you can do it that way, but it means more connections to leak. Using a dual-function sender such as the OP6670 means you can run both the gauge and the light from just the one sender.
The plug-in connector can be had off any '90-up Chrysler product that has an oil pressure gauge. Dodge trucks and vans, Spirits and Acclaims, there are lots of options.
