It is currently Sun Nov 22, 2026 10:49 am
 Post subject: How mutch is too mutch??
PostPosted: Tue Sep 05, 2006 8:55 am
Just wondering how mutch do you rpm your slant´s??i have a 65 valiant whit an 225 and it rpm 6000 easy......i havent given it more cos i get the filing something wil come out of the engine and say hi and that wouldent be fun at al,am i pushing the limit??
PostPosted: Tue Sep 05, 2006 10:12 am
For a stock engine, yes. I'd keep it below 5k for peace of mind. Not sure how you're getting a stock engine to make power up to 6k though; most taper off around 4500.
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
PostPosted: Tue Sep 05, 2006 10:29 am
I am shifting mine at 6200 on nitrous with stock rods. I haven't killed a rod yet. :shock:
PostPosted: Tue Sep 05, 2006 10:32 am
What about the rod bolts? Are they stock as well? If so, then I feel a lot better about skimping and not buying the ARP's when I did my rebuild.
Used to own:
'82 Dodge D150
My other passion
PostPosted: Tue Sep 05, 2006 11:09 am
everything is stock exept the carb.....its a edelbrock 500.whit the original 1bbl it did about 4500.....nothing else should be done on the engine!
PostPosted: Tue Sep 05, 2006 12:06 pm
Sorry, ARP bolts in mine. :shock:
PostPosted: Tue Sep 05, 2006 12:48 pm
I have ARP Rod Bolts in Mine Turns 6200 Day and Night.
PostPosted: Tue Sep 05, 2006 4:44 pm
mine revs 6k with everything inside the short block (except for the cam) and a holley 2300 500cfm.
Juan Ignacio Caino
