It is currently Sun Nov 15, 2026 12:26 pm
PostPosted: Wed Sep 13, 2006 8:35 am
I'm replacing the rear pads on my 85' D100. Problem I ran into was there is no "nipple" on the new pads for my automatic slack adjust "cam". I looked in my hardware kit didn't see anything. Has anybody ran into this problem, if so what was the fix? I don't mind adjusting my brakes periodically but it would be nice if the auto slack adjusters worked.
Thanks
85' D100
225cid
A833OD
PostPosted: Wed Sep 13, 2006 9:49 am
Pound out the old pin, put it in your new shoes. Put a socket under the pin when you drive it out (using a punch). Use a C clamp or vise to reinstall.
PostPosted: Wed Sep 13, 2006 1:17 pm
Thanks Eric, I'll give that a try.
85' D100
225cid
A833OD
