It is currently Mon May 18, 2026 9:02 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: Oil Press Drop
PostPosted: Sun Dec 09, 2001 5:41 pm
I've noticed that on hard stops my oil pressure drops to 0 psi then returns to 40-50 lbs. I assume this is caused by oil puhing up in the pan and returning....Is this normal on a 65 - 225 ?
I figured when I overhaul my Engine soon..I would build some baffles along with a windage screen. Any other Ideas?
soupitup@msn.com
PostPosted: Tue Dec 11, 2001 9:16 am
: I've noticed that on hard stops my oil pressure
: drops to 0 psi then returns to 40-50 lbs. I
: assume this is caused by oil puhing up in
: the pan and returning....Is this normal on a
: 65 - 225 ?
: I figured when I overhaul my Engine soon..I
: would build some baffles along with a
: windage screen. Any other Ideas?
I would weld a couple of baffels into the pan and be sure the oil pick-up tube is correct for that year oil pan and positioned close to the pan's floor.
Tip: When doing pan baffels and windage trays, always check all clearances, including the dip stick's clearance.
PostPosted: Tue Dec 11, 2001 2:32 pm
: I would weld a couple of baffels into the pan
: and be sure the oil pick-up tube is correct
: for that year oil pan and positioned close
: to the pan's floor.
: Tip: When doing pan baffels and windage trays,
: always check all clearances, including the
: dip stick's clearance.
: DD
I'll guess that last bit's a wee reference to my recent snafu... very polite.
PostPosted: Tue Dec 11, 2001 5:49 pm
: I'll guess that last bit's a wee reference to
: my recent snafu... very polite.
: Lou
As they say...been there, done that,...
and it sounds like I am not the only one to put a nice oil pan / windage set-up onto an engine, just to find-out that the dip stick no longer has a place to get through to the sump. :-(
