It is currently Sun Dec 01, 2024 12:42 pm
 Post subject: Head Bolt Source
PostPosted: Tue Sep 19, 2006 11:13 am
Anyone know a source for cylinder head bolts, Dorman Part #675121? I placed an order with RockAuto, but they say they've been discontinued...
vm
PostPosted: Tue Sep 19, 2006 12:11 pm
If you want to step up to studs:
http://www.slantsix.org/articles/ARP-st ... rdware.htm
PostPosted: Tue Sep 19, 2006 12:54 pm
Nope — don't want studs. At least not for the cylinder head. I started installing the head and manifolds as a single unit to avoid the difficulty of that center lower manifold nut, and it's hard enough to do as is.
If no one knows of a source, I'll just reuse the existing bolts.
vm
PostPosted: Tue Sep 19, 2006 1:27 pm
I have never replaced a head bolt, and never had one break/strip. I have used some of them at least 5x over (head swap, rebuild...) and usually torque them to >80ft-lbs (wet with oil).
PostPosted: Tue Sep 19, 2006 2:25 pm
I snapped one in one ocasion when my torque wrench got sc**wed up and I didn't notice and tighten it in excess of 12 kg/cm2.
Other than that, I always reuse them.... What is wrong with them? bad threads? Is hard to see one of those wear bad enough not to reuse them if you can get them... I have one set of ARP's that I got for feeling that I wasn't beeing THAT cheap, but never installed them yet. Got con rods, mains and head arp kits. Really nice stuff...
Juan Ignacio Caino
PostPosted: Tue Sep 19, 2006 3:25 pm
My understanding is that the ARP bolt are a real good idea if your engine is blown or using nitrous. These bolts are less likely to stretch under the load. I would think that the stock bolt would be good otherwise. I did have one main cap bolt on a Chevy small block that almost came up to spec and then it got easier and easier to turn. The bolt was turning into a screw instead of a bolt. :shock: A new bolt fixed this. (sorry about the nonSlant reference)
PostPosted: Wed Sep 20, 2006 6:34 am
I'm sure the stock bolts are fine, but I'm trying to take the opportunity to replace all of the 35 year old parts that I can, and new bolts are cheap insurance.
But, eventually, somebody's going to need a new head bolt or two. Are they gonna have to go to studs? That would kinda suck.
vm
PostPosted: Wed Sep 20, 2006 12:07 pm
can you tell us the head bolt part number?
PostPosted: Wed Sep 20, 2006 12:51 pm
ehh.... nope... head studs (not bolts) I got them slightly used, as well as mains. I said I got for feeling that I wasn't beeing THAT cheap... the THAT part explaining it perfectly! :lol:
Juan Ignacio Caino
PostPosted: Wed Sep 20, 2006 1:31 pm
I prefer stock headbolts for most engines, and that's what I have. I just posted the ARP stuff because I knew where it was. :wink:
If you have any doubt about critical bolts, it is a good idea to replace them. Metal does change over time, and who knows what those fasteners have been through?
PostPosted: Wed Sep 20, 2006 5:03 pm
Car Model: 1967 Dodge Dart 270
The ARP head bolts are nice, but $75 is a lot for some bolts, nuts & washers. :shock: But I still run them in my car :D
PostPosted: Wed Sep 20, 2006 5:18 pm
there's a seller's store in ebay that sells them new for 50 bucks IIRC
Juan Ignacio Caino
PostPosted: Thu Sep 21, 2006 4:52 am
PAW sells them cheaper than that.........
PostPosted: Thu Sep 21, 2006 8:35 am
I haven't found ARP or PAW head bolts, only studs. Any part numbers?
vm
PostPosted: Thu Sep 21, 2006 10:23 am
Cant you put the studs on after the head is down just like a bolt anyway? Some are even made this way with a allen head top or screw driver slot. If not dubble nut or sloting them wouldnt be to hard.
Jess
Users browsing this forum: Bing [Bot], Google [Bot] and 14 guests
