It is currently Fri Nov 29, 2024 4:49 am
Post new topic  Reply to topic  [ 31 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Wed Sep 20, 2006 7:15 pm
Ah,,,,the 11 second barrier......
PostPosted: Wed Sep 20, 2006 7:19 pm
mmmm......looks like this project will be more costly than I thought, I can get a TBird supercharger for 80 dollars (is working well), but the blow-through carb will be a real problem to get here.
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
PostPosted: Wed Sep 20, 2006 7:39 pm
If you're willing to go the four barrel route (and can get a holley relatively cheaply), there's instructions all over the net for how to rig them up to work as blow through. It doesn't look like that bad of a process.
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
PostPosted: Thu Sep 21, 2006 11:57 am
Car Model: 1964 Dart GT
You can always go with a draw through on a roots type blower. The expensive and /or time consuming part of installing any blower on a slant is custom made parts (pulley, bracket, etc).
PostPosted: Thu Sep 21, 2006 12:08 pm
It ain't as easy as it looks on paper. :D :roll: :shock:
PostPosted: Thu Sep 21, 2006 1:06 pm
How would you know? :twisted: :wink:
PostPosted: Thu Sep 21, 2006 2:16 pm
Too many broken pistons and a dead wallet. :roll: :shock:
PostPosted: Thu Sep 21, 2006 2:51 pm
Add fuel and oxygen until piston melts ....then back off 2 steps. Repeat as necessary.
Add fuel and oxygen until piston melts ....then back off 2 steps. Repeat as necessary.........Looks easy to me....
PostPosted: Thu Sep 21, 2006 5:08 pm
Wanna bankroll my next attempt tough guy? :lol: :lol: :lol: :lol:
PostPosted: Thu Sep 21, 2006 9:01 pm
Tell me the truth, is worth the time and money to supercharge/turbocharge a slant? supercharge my slant is hitting the 400 dollars mark and can go up to 600 dollars, while putting a 360 V8 with anything to make it run cost me 420 dollars.
Also I need the hood to close well or with a small scoop (no more than 2 inches tall), currently my car is parked in the street so is not a good idea to make it to attractive to certain eyes.
Valiant Duster 1971
PostPosted: Fri Sep 22, 2006 5:37 am
What is your goal? If your intention is to go as fast as possible with the smallest initial financial investment, then yes, you should swap in the 360.
vm
PostPosted: Fri Sep 22, 2006 8:10 am
My goal is speed and mileage, the best of both for a street car in a country with no car mod laws.
Valiant Duster 1971
PostPosted: Fri Sep 22, 2006 9:31 am
Then I would suggest a blown slant or a small V-8 (273 or 318), not a 360.
vm
PostPosted: Fri Sep 22, 2006 9:46 am
Turbo is probably cheaper than a supercharger to get and make work on a slant. I have never done a turbo slant, and for that matter completed a blower on a slant...yet. If you are in love with the slant, keep it and make it run like you want it to. V8 conversion is the easiest for a power increase since pre-made parts are available to complete the conversion. Since this is the "Slant 6" site, I personally would turbo the slant.
Users browsing this forum: Ahrefs [Bot] and 17 guests
