It is currently Tue May 12, 2026 5:13 pm
PostPosted: Sat Oct 14, 2006 7:04 pm
i have a 67 van with a 225 motor and a727 tran's it has an adapter from factory and tran's looks to have v-8 bolt pattern on bellhousing would this tran's have a high stall converter being behind a 225 and being a heavy duty tran's :?: just like to know if it is possible thanks
PostPosted: Sun Oct 15, 2006 9:09 pm
Look at the ring gear on the converter. If it's about 3/8" wide you have the larger, lower stall converter. If the ring gear is nearly 1" wide you have the smaller, higher stall converter. Chances are poor you have the high stall.
PostPosted: Sun Oct 15, 2006 10:39 pm
What year range does that apply to? All slants, or just the ones that came factory with the small block adapter?
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
PostPosted: Sun Oct 15, 2006 11:13 pm
Anything with a 727. 904s only came with the small torque converter.
PostPosted: Sun Oct 15, 2006 11:16 pm
Hm... mine came with a high stall converter, but it has the thinner ring gear. The replacement (parts store rebuild) was identical. Don't know how it compares in size to the low stall. Of course mine is one of the later models with hydraulic lock-up. Could that be the difference?
Used to own:
'82 Dodge D150
My other passion
PostPosted: Mon Oct 16, 2006 6:17 am
There are different variations in the large (12") and small (11") converters. You have the higher stall big torque converter. The smaller torque converter is higher stall yet. I don't know if they made an 11" lockup converter for the 727 or not. Obviously the lockup 904 uses an 11" lockup converter so you could likely have one made to fit the 727.
PostPosted: Mon Oct 16, 2006 12:45 pm
Ah, gotcha. Thanks for the clarification.
Used to own:
'82 Dodge D150
My other passion
Users browsing this forum: Bing [Bot] and 6 guests
