It is currently Thu Dec 25, 2025 7:31 pm
 Post subject: bolt pattern??!
PostPosted: Tue Oct 24, 2006 6:10 pm
can a 5x4.75 bp rim fit on a 5x4.5 bp ?
i need to know because i need to buy a set of rims for my 73 swinger
________
YZF-R1
________
Nevada Medical Marijuana
Last edited by 15Standtriumphant on Thu Feb 17, 2011 6:46 am, edited 2 times in total.
PostPosted: Tue Oct 24, 2006 6:14 pm
There are uni-lug wheels that have oval bolt holes, but unless the wheels are made this way, no. Also, most Chevy wheels aren't offset in far enough for an A body. For example, most 7" wide Chevy wheels have 3.5" of backspace while original Chrysler 15x7" wheels have 4 1/4" backspacing. That 3/4" makes a big difference on the tires you can use.
PostPosted: Tue Oct 24, 2006 6:37 pm
what if i wanted to use mustang wheels on my mopar?
these are the specs:0mm offset, 4.50" backspacing.
________
BUY CANNABIS SEEDS
________
Willys Jeep Wagon Specifications
PostPosted: Tue Oct 24, 2006 7:29 pm
So they are 8" wide? How about the rest of the specs? Chances are they will stick out a little too far.
PostPosted: Tue Oct 24, 2006 8:42 pm
well, they are 17x8 with a 5x4.5 bp
backspacing is "4.50
i will also be using a rear lift kit,but nothing too dramatic.
________
Honda Sh150I
________
Michigan Medical Marijuana Dispensaries
PostPosted: Tue Oct 24, 2006 8:48 pm
Hmm, my 17x8" Mustang wheels have nearly 5 3/4" backspacing. They fit on the front of my '72 Swinger (with '73+ disc brakes) without a spacer. The back requires a spacer about 3/4-1" thick. I'm using a different rear axle so I don't have to use spacers. The wheels in question will likely rub on the front fenders, but would fit the back ok.
One other thing. Lifting the back of the car will hurt the handling.
PostPosted: Tue Oct 24, 2006 8:52 pm
so what i need to do is get a rear 3/4 spacer on my drums?
becasue i was planning on cutting out my rear quarter wall in order to fit the well diameter. so, technically, wouldnt the spacer just cause more tight fitment on the panel?
________
Mercedes-benz 500e history
________
Medical cannabis seeds
PostPosted: Tue Oct 24, 2006 8:59 pm
If you use the factory Ford +30mm offset wheels you need a 3/4" to 1" spacer. With an 8" wheel with 0 offset you will not need a spacer. 245/45R17 tires will fit a '73 Swinger without cutting anything if you use the right combination of axle width and wheel offset.
PostPosted: Tue Oct 24, 2006 9:06 pm
so then my only problem now is just buying the wheels, right?
________
Buy Roor Bongs
________
Greece Recipes
Last edited by 15Standtriumphant on Thu Feb 17, 2011 6:47 am, edited 2 times in total.
PostPosted: Tue Oct 24, 2006 10:14 pm
I really can't say.
PostPosted: Wed Oct 25, 2006 3:05 am
Car Model: '23 T-bucket
You MUST get wheels with a 5 lug, 4 inch pattern. Anything else will quite literally, not fit over your lug studs. The back spacing can be determined and calculated, but it's irrelevant if the bolt pattern isn't right.
Do NOT go the route of wheel adapters. They have a tendency to fail at the worst time, and are generally unsafe.
Roger
PostPosted: Wed Oct 25, 2006 4:37 am
Amen! There are numerous wheel and tire combinations available, don't risk your life on something that doesn't fit.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Wed Oct 25, 2006 10:59 am
Roger
His car is a '75, so it might have 5 on 4.5" lug spacing from the factory.
PostPosted: Wed Oct 25, 2006 2:00 pm
Whoops! :oops: You're right. Correct my last.....it'll be the 5-on-4.5" pattern.
Roger
PostPosted: Tue Oct 31, 2006 4:27 pm
so if my wheels have a 5.75 backspacing they'll fit?
and, how bad is the rear lifting, even if its only 2 inches?
i just recently purchased a lift kit way cheap on ebay and was thinking of throwing it on. it'll be a daily driver, so whats the best way to go to lift up to 2 inches.
________
220
________
Zx14 Vs Hayabusa
