It is currently Fri May 15, 2026 5:07 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
 Post subject: intake gaskets
PostPosted: Tue Jan 01, 2002 11:49 am
Are there any variances in the intake port sizes in the different brands you have used? I don't suppose anybody makes a "race port" gasket like the Fel-pro 1262 as opposed to the standard port 1205 for small block fords.
glovert@southwestern.edu
 Post subject: Re: intake gaskets
PostPosted: Tue Jan 01, 2002 12:04 pm
: Are there any variances in the intake port
: sizes in the different brands you have used?
: I don't suppose anybody makes a "race
: port" gasket like the Fel-pro 1262 as
: opposed to the standard port 1205 for small
: block fords.
The Clifford gasket has a slightly larger port "cut" to it.
For a true large port, super HD intake gasket, contact the Cox Boys, they have them.
PostPosted: Tue Jan 01, 2002 3:14 pm
: The Clifford gasket has a slightly larger port
: "cut" to it.
: For a true large port, super HD intake gasket,
: contact the Cox Boys, they have them.
: DD
Go for the Cox Bros. gasket. Open the ports up to whatever size you want. It has lots of meat around the ports, and is extra thick for good sealing. Contact
Cox Bros. Inc.
1467 Weldon Ave.
Columbus, Oh 43224
614-268-9920
e-mail <A HREF="mailto:CoxBros66@msn.com">CoxBros66@msn.com</A>
Charlie
flturbo6@aol.com
PostPosted: Thu Jan 03, 2002 5:59 pm
: "cut" to it.
: DD
I have have a lot of trouble sealing off intake leaks with the standard gasket.
Anyone have any tricks? Also, does anyone make a intake gasket that seals better than the stock Felpro?
uscl@staffing.net
PostPosted: Thu Jan 03, 2002 6:50 pm
: I have have a lot of trouble sealing off intake
: leaks with the standard gasket.
: Anyone have any tricks? Also, does anyone make
: a intake gasket that seals better than the
: stock Felpro?
Use the Cox Bros gasket, see my post above for contact info.
Charlie
flturbo6@aol.com
