It is currently Sat Nov 14, 2026 4:47 am
 Post subject: Hump Location
PostPosted: Fri Oct 27, 2006 3:40 am
I Ordered A Fiberglass Hump From Brewers Yesterday And Was Wondering: What would Be The Best Method To Mount The composite piece To My Sheetmetal?
And;
Is There A Measurement I Should Be Aware Of As Far As The Placement Is Concerned? Or Will It Become Obvious When It Finds My Floorpan?
( I Realize Some Of You Are Asking Yourself 'Why Dosent This Guy Just Set It Up Atop The Shifter?' Well I Still Need To Find One; But I Might As Well Put My Interior Back Together While I Searching Right? {Read: My Significant Other Is Getting Frustrated With The Cold, Loud, Bare Interior} )
Any Help Would Be Appreciated
Seth
PostPosted: Sun Oct 29, 2006 4:09 pm
I woud use sheet metal screws. And it is rather obvious where it will go.
PostPosted: Wed Nov 01, 2006 2:44 pm
after you put a couple sheet metal screws in to hold it in place I'd buy some fiberglass cloth and resin, then wire wheel the floorboards a few inches around it and fiberglass it in. Youll never see it under the carpet, and itll cut way down on interior noise. I did the whole floorboard this way in my 78 D 300 Dually. Drivers floorpan had "heel holes", passenger side was just "peppered" with holes, basically solid. I welded patches in on the drivers side then fiberglassed the whole floor. You wouldnt believe how much quieter it will be inside!
PostPosted: Wed Nov 01, 2006 5:13 pm
Right On! Quiet Is Most Deff. A Huge Plus!
PostPosted: Wed Nov 01, 2006 6:35 pm
Just be sure that you do the job right or it will peel off like a band aid. You can't just lay the cloth and brush the resin on. get like a paint roller tray or maybe a few "flats" from the local liquor store, just enuf of a lip on the side to keep the stuff from running all over the place, mix up some resin/hardener, cut the fiberglass cloth in 1-1/2-2" wide strips, and dip the cloth in the resin, then spread it out, overlapping the edges of the hump and the floor, as well as the edges of the f-glass cloth you just laid down, if you do this right you can keep overlapping the edges, then put a 2nd layer over the top, once it dries, you won't be able to see the seams between the cloth strips, itll all dry together and be extremely solid. watch out for air pockets though Use some latex gloves, and smooth it out with your fingers, you can try rolling it out with a small roller like they use for wallpaper, etc. Careful here though, the cloth might want to stick to and roll up with the roller. Messy yes but solid and worth it.
PostPosted: Thu Nov 02, 2006 1:59 pm
Thank You For The Walkthrough.
