It is currently Fri May 22, 2026 10:26 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 18 posts ]  Go to page Previous 1 2
 Post subject: Dave and Dave
PostPosted: Tue Jan 08, 2002 2:09 pm
Thanks for all the good responses. I really appreciate the time you took to clarify a confusing situation. Seems like there is always an expert or two to answer the technical questions asked on this forum.
Now if someone could just explain why a field-loads relay is used on B and C bodies and not the A bodies. I'm kidding, guys!
lancer_41@excite.com
PostPosted: Sat Jan 12, 2002 4:00 pm
: The early ECU's had 5 pins and used the dual
: ballast resistor. The later ECU's were
: redesigned to use 4 pins and a single
: ballast resistor (or only half of the dual
: ballast resistor if you use a 4 pin ECU to
: replace a 5 pin unit).
: I'll dig up some more info to post later if
: someone does not beat me to it.
If there is someone that could draw out a diagram of all this, I would buy them a beer! I am swapping to e,ignition myself and have already bought the dual ballast resistor and twin field alt. The ign. I am going to use is from a 74 scamp. I cant make sense out of the above conversation!:)
Myblue684x4@Aol.com
PostPosted: Mon Jan 14, 2002 12:52 pm
: If there is someone that could draw out a
: diagram of all this, I would buy them a
: beer! I am swapping to e,ignition myself and
: have already bought the dual ballast
: resistor and twin field alt. The ign. I am
: going to use is from a 74 scamp. I cant make
: sense out of the above conversation!:
Someone has already noted there is an error in the second and third diagrams at <A HREF="http://www.valiant.org/electrical-diagr ... ms.html</A> . In both diagrams, the blue wire from the alternator field should go to the I terminal on the voltage regulator, not the mounting hole.
(I've sent corrected drawings to Dr Dave, but he hasn't had time to post them yet.)
On diagram three, the numbeer three pin on the ignition module isn't shown because it isn't used. This is also indicated at <A HREF="http://www.slantsix.org/articles/elect_ ... ing.htm</A> . If you are using a dual ballast resister, Connect pin three to the "extra" connection on the dual resistor.
If you can use AutoCad drawings, let me know and I'll send one.
I prefer New Taiwan Beer, but will settle for Michelob.
Dave W
dwordinger@earrthlink.net
