It is currently Sun May 17, 2026 4:55 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 8 posts ]
 Post subject: DANA 44
PostPosted: Sun Jan 13, 2002 1:47 pm
i ve got a dana 44 rear axle from a 98 grand cherokee, but it lacks the diskbrakes ...well everything from the brakes, and because i live in finland i would need some help of you guys ...is there some place that has these things, so i could get em?
i will put the rear in my Duster, someday when i have all the parts...its a really nice axle, Light, strong and 3.73 gears, and a "locker"...
any info or a site where i could see what im actually missing would be nice. thanks.
http://homepage.mac.com/jyrie
jyri.eramaa@jwt.fi
 Post subject: Re: DANA 44
PostPosted: Sun Jan 13, 2002 5:37 pm
: i ve got a dana 44 rear axle from a 98 grand
: cherokee, but it lacks the diskbrakes
: ...well everything from the brakes, and
: because i live in finland i would need some
: help of you guys ...is there some place that
: has these things, so i could get em?
The Dana 44 is actually a darn good axle, used in the front of a bunch of full-size 4X4's from the mid-70's up until the late 80's. The problem many of us are going to have finding you the brake parts are that many yards don't want to part out an axle assy. in that manner, usually wanting to sell the entire unit. Getting new parts for it would be BIG $$$$.
: i will put the rear in my Duster, someday when
: i have all the parts...its a really nice
: axle, Light, strong and 3.73 gears, and a
: "locker"...
You're very right on all counts. Heck, you could even go the air locker route, if it were practical for you. You will, I'm sure, have to mount spring pads on the axle tubes, (in the right locations), to put it under your Mopar, but that's no big deal.
BTW, how do I know?....I've got four of 'em, all under the front & rear of I.H. Scout2 project trucks, (well, one is a parts donor).
Roger
GTS225@aol.com
PostPosted: Sun Jan 13, 2002 8:13 pm
: The Dana 44 is actually a darn good axle, used
: in the front of a bunch of full-size 4X4's
: from the mid-70's up until the late 80's.
You might check for recalls on the 98 Grand Cherokee. there were a slew of problems and replacements from the 95-98 Cherokee and Grand Cherokee. One as I remember right, had to do with the aluminum casing on some of those rear ends.
just an FYI,
PostPosted: Mon Jan 14, 2002 3:52 am
: One as I remember right, had to do with the aluminum casing on some of those rear ends.
Whoa.....now I didn't know that Dana had changed the punkin' over to aluminum. That changes my previous. I know about the iron center/steel tube diffs, and those are good. I'd venture to say only one step below the tried-&-true 8.75. I don't know whether one could get a true spool for it, but the locker route is real close.
Roger
GTS225@aol.com
PostPosted: Mon Jan 14, 2002 7:12 am
: Whoa.....now I didn't know that Dana had
: changed the punkin' over to aluminum. That
: changes my previous. I know about the iron
: center/steel tube diffs, and those are good.
: I'd venture to say only one step below the
: tried-&-true 8.75. I don't know whether one
: could get a true spool for it, but the
: locker route is real close.
: Roger
yeah its aluminium, thats why i like it...light makes you might...well if you ever get to the end of the track...hehe.
i have to cut the brackets of...of the 4-links???
some noise problems Whining gears? dont know, but the whine from the 7 1/4 was soooo bad that i dont mind of a small noise.
is there a site in the web that sells these parts?
thanks for the info.
jyri.eramaa@jwt.fi
PostPosted: Mon Jan 14, 2002 9:14 am
:If I'm not mistaken all "Dispatcher" mail Jeeps used a Dana 44 with 3.73 gears and limited slip. Plentiful, strong, narrow and 5 on 4.5 bolt pattern.
: The problem many of us are going to have
: finding you the brake parts are that many
: yards don't want to part out an axle assy.
: in that manner, usually wanting to sell the
: entire unit. Getting new parts for it would
: be BIG $$$$.
: You're very right on all counts. Heck, you
: could even go the air locker route, if it
: were practical for you. You will, I'm sure,
: have to mount spring pads on the axle tubes,
: (in the right locations), to put it under
: your Mopar, but that's no big deal.
: BTW, how do I know?....I've got four of 'em,
: all under the front & rear of I.H.
: Scout2 project trucks, (well, one is a parts
: donor).
: Roger
motorhedfred@yahoo.com
PostPosted: Mon Jan 14, 2002 1:29 pm
: yeah its aluminium, thats why i like it...light
: makes you might...well if you ever get to
: the end of the track...hehe.
Ok, well, if your using it in a slant car, and it won't see REAL hard launches, I see no reason it shouldn't work
: i have to cut the brackets of...of the
: 4-links???
That depends. If you're going to set your car up with a four-link and coil-over shocks, you might be able to use the existing brackets. However, if you're putting this into an A-body, using the original leaf springs, you'll need to weld on a couple spring perches for the leafs to bolt to. THEN you might have to remove the four-link brackets, if they're in the way, otherwise, they won't hurt anything leaving them there.
: some noise problems Whining gears?
If set up correctly, shouldn't be any noise out of the ordinary
: is there a site in the web that sells these
: parts?
Sorry, boss. Don't know of any right offhand. You could probably locate a few by searching for salvage yards on the web, or dealer parts sales.
Roger
GTS225@aol.com
PostPosted: Mon Jan 14, 2002 5:02 pm
The aluminum D44 issue has been tossed around alot on the Jeep TJ,XJ,YJ,ZJ web sites. You can find all the info you want by doing a little searching in the jeep world. Might check some <A HREF="http://www.off-road.com/jeep/tech/conva ... 44.html</A>& <A HREF="http://www.TJ-list.org">www.TJ-list.org</A>. I haven't heard of any strenght issues surrounding the aluminum case. Biggest issue is carrier and ring&pinion differences between the cast iron version and the aluminum. Less aftermarket support for the alumn versions. The alumn version is a c-clip, unlike the iron case version. Keep in mind all modern D44's are 30spline, like the 8-3/4, and has a similar sized ring gear.. (same diff assy used IRS vetts)..I think it'll hold up to all you can toss it's way..
matt-
mhaskell@reliant.com
