It is currently Fri Jan 02, 2026 7:59 pm
 Post subject: Ready to do ELB removal
PostPosted: Thu Dec 21, 2006 12:06 pm
I have New/Rebuilt Distributor and 4 pin module along with single ballast resistor. I intend to make the harness, As it appears very simple with a correct schematic. Once satisfied with results I want to remove anything unnecessary. I also will post a pic of Carter 2bbl in another topic for advice on it. Where should the Dist Vac connect? Any comments or advice is appreciated.
PostPosted: Thu Dec 21, 2006 1:44 pm
Iirc, it's the same port that the vacuum pod on the ELB connected to.
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
PostPosted: Thu Dec 21, 2006 5:46 pm
I'm not sure that's so...my recollection is that the ELB sees manifold vacuum, while the distributor vacuum advance wants to ssee ported vacuum. I don't think carbs originally used with ELB have ported vacuum available. :-(
