It is currently Fri Nov 20, 2026 6:39 pm
 Post subject: Gear spacer?
PostPosted: Sun Jan 28, 2007 3:25 pm
Hey guys, I think I rued up........
After getting my oil pan/timing cover buttoned up nicely, I noticed a part there on the ground.... :? Its a flat "tin" about 3in across, with a keyway cut in it. I'm afraid it was supposed to go inside the timing cover. Ya'll please tell me I'm wrong!! If it does go inside the cover, what purpose does it serve, I mean, could I leave it off?(Probably a crazy statement)
I think I'm going OK, then I read things like Vynn3's trouble, and I get antsy! (Hope you get it worked out, man. :oops: :) )
225 Cubic Inches of Iron-Head American Muscle
225 bored .040 /.100 off block, Schneider Cam 224@.050~ .480 lift - Stock valves, blended bowls, Offenhauser intake with 500 Edelbrock carb
 Post subject: Der oil slinger...
PostPosted: Sun Jan 28, 2007 3:26 pm
That part is the oil slinger, late slant sixes ran fine without them, it's a nice part to install to keep the oil off the front seal though....
PostPosted: Sun Jan 28, 2007 3:51 pm
Hey, BBB, I did the exact, same thing when I put my engine together.
Realized it about the same time you did, too!
After reading around, I got answers like D.Idiot's, so I resolved not to worry about it, but be more careful next time.
Thanks for the well wishes. I'm pretty down right now. :cry:
vm
Users browsing this forum: Ahrefs [Bot] and 5 guests
