It is currently Sun Jan 12, 2025 2:22 am
 Post subject: Engine ID ?
PostPosted: Mon Jan 15, 2007 11:12 am
Car Model: 62 Lancer GT
I have beening searching old posts all afternoon but can't find an answer. I am looking at an engine I might buy for a rebuild. The numbers on the pad near the coil are 225R 250706 14. Can anyone decipher this. The motor was pulled from a 71 Demon. It is possible the numbers sre 205706 14. From what I got from the old posts the the first four 2507(2057) Are the date code?
1966 Dart GT
4 spd. OD conversion
8 3/4 - 3.55 SG (Sold)
62 Lancer GT
B Body 8 3/4
PostPosted: Wed Jan 17, 2007 3:16 pm
I found an old post where someone decoded the first four of 2647 as april 29th 1968. Which I couldn't figure out. Bumping this up.
1966 Dart GT
62 Lancer GT
B Body 8 3/4
PostPosted: Tue Jan 30, 2007 7:31 pm
Just bumping this up. I am thinking of buying this motor.
1966 Dart GT
62 Lancer GT
B Body 8 3/4
 Post subject: Re: Engine ID ?
PostPosted: Wed Jan 31, 2007 10:02 am
H'mmm. Probably not a '71 engine by those numbers. The first four digits following the displacement (2507 in your case) are the date code, and '70-'71 model year date codes ran from 2957 to 3686. Your 2507 corresponds to June 8, 1968. The 0614 is the daily serial number, so this would've been the 614th 225 engine built at that particular plant on 6/8/68. But, there is still the mystery of your "225R". Your engine ID pad would read PM225 25070614 if the engine were built at Mound Road, PT225(...) if it were built at Trenton. And "R" was used in the late '60s/early '70s as the engine plant code for Windsor, Ontario. So, what you are probably looking at is a 225 made at Windsor Engine Plant on June 8, 1968.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 4 guests
