It is currently Wed May 13, 2026 8:22 pm
 Post subject: V8 dakota 5 speed?
PostPosted: Sat Feb 10, 2007 8:39 am
I'm not sure they ever came with one. but would this five speed and bellhousing for 318. theoretically mate to the SS/SB bell adapters you see every now and then. The old ones used for the 727 back in the day ( or was it the 904?)
64' Valiant Signet 5.9, 64' Dart 170 moredoor 3.7, 67' A100 3.7, 00' Dakota SLT 4.7
PostPosted: Sun Feb 11, 2007 3:07 am
There's no reason it couldnt be made to fit with some work on the hump. The real question is would you really want to? I had an '87 Dakota with a five speed and it was definitely a truck tranny with a heavy feel and you did not want to be in a hurry to make a shift. Unless the later ones are different I would not find it suitable for use in a car.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Mon Feb 12, 2007 7:43 am
Here's a couple of threads on one experience with this trans and how he swapped it in. Just an FYI.
http://slantsix.org/forum/viewtopic.php?t=10197
http://slantsix.org/forum/viewtopic.php?t=12614
'15 Chrysler 200S V6
'74 Duster 360, factory 4 speed car
PostPosted: Tue Feb 13, 2007 8:05 pm
thanks for the info. not terribly interested in that trans, but more interested in what I might do with the trans adapter I found at a swap meet a couple weekends ago. had to buy it a $50. came with the plate the motor brace, all bolts and the hub between the crank and flywheel.
PostPosted: Tue Feb 13, 2007 9:01 pm
The answer then is yes, you can bolt up a Dakota bell and trans to that adapter. The way to go would be the Dakota 3.9 V6/5.2 V8 bell for an AX15 bolted to a Supra R154.
Read farther down this thread for some input.
Maybe that will be more helpful.
