It is currently Wed Oct 14, 2026 10:34 am
 Post subject: fuel pump
PostPosted: Thu Mar 01, 2007 6:59 pm
Is the the fuel pump on the slant the same as all small blocks ? And if not can I get a hp pump for my 225?
 Post subject: Re: fuel pump
PostPosted: Thu Mar 01, 2007 8:34 pm
The Mopar Big Block fuel pump is a closer match but you still have to swap-in the "arm" from a SL6 fuel pump.
PostPosted: Fri Mar 02, 2007 4:07 am
Use an electric one, its easier, just have it hooked up to an oil pressure switch to switch it on. I think CAT have them in that thread size, have used them before on 351C Ford and other brands of vehicles.
PostPosted: Fri Mar 02, 2007 7:19 am
Aftermarket electric pumps can be noisy for an everyday driver.
'63 Valiant V200 Convertible
225 Aluminum Block
PostPosted: Fri Mar 02, 2007 7:47 am
Agreed, I will not put an electric pump on a car not originally so equipped without a good reason (such as a fuel injection retrofit). I do not find them "easier" or more convenient on street-driven carbureted cars. They are also usually noisy, and can be quite unsafe.
PostPosted: Fri Mar 02, 2007 11:32 am
Online
Unless you are running more than about 250HP (14s 1/4 miles in a 3000lb car), then the stock pump should be just fine. I have two cars in that range to prove it...
PostPosted: Fri Mar 02, 2007 6:10 pm
With having an electric fuel pump, its easier to hook up with an immobiliser to stop theft. If you mount an elect' fuel pump properly, it hardly makes a noise. I have one on my SV1 and you can't hear it.
The pump is a Pierberg roller cell type, not a Facet type.
If you have a crash, and the engine stalls, there's no oil pressure, so the pump don't go, that is what I meant with having it hooked up to a pressure switch, to make it work.
Users browsing this forum: Google [Bot] and 19 guests
