It is currently Sun Oct 11, 2026 6:02 pm
 Post subject: Balancers
PostPosted: Mon Mar 05, 2007 11:37 am
COULD A GUY USE A BALANCER FROM A 440 ON A SLANT? WHADDA YA NEED TO CHANGE TO MAKE THIS HAPPEN?
pfm
PostPosted: Mon Mar 05, 2007 1:40 pm
The factory BB Mopar dampener will bolt-onto a SL6 but it will stick-out from the timing cover by a few inches.
There is no groove in the BB dampener so you would have to make a custom pulley system to drive the water pump and accessories.
 Post subject: balancer
PostPosted: Mon Mar 05, 2007 4:37 pm
i run a 440 balancer, the timing cover oil seal has to be swaped for a 440s and the balancer can be machined for the belt groove just mark it the same distance out from timing cover and bring it to machine shop they can cut it to the dimension as stock balancer :D
PostPosted: Mon Mar 05, 2007 8:36 pm
COULD A BALANCER APPEAR TO BE IN GOOD SHAPE AND STILL CAUSE A NASTY VIBRATION? MY SEARCH FOR A NEW OR REMANED STOCK REPLACEMENT HAS BEEN UNFRUITFUL. ANYONE KNOW WHERE TO FIND ONE?
pfm
PostPosted: Mon Mar 05, 2007 8:44 pm
I have a few good used ones if needed.
If the dampener has a visable wobble at idle then it can cause vibration at speed. If it spins 'true', it is not the cause of your vibration problem.
PostPosted: Tue Mar 06, 2007 12:03 am
They are still available in Australia, and there were only 2 sorts here. The timing marks are in different places, but otherwise the same.
 Post subject: Junkyard and then....
PostPosted: Tue Mar 06, 2007 6:50 am
To answer the remanf balancer question,
Damper Dudes and Damper Doctor both out of California can reman any balancer...I tested both a year back sending out a couple of spare dampers and both came back about the same time, rebuild looked good, and both had about the same price...
-D.idiot
Users browsing this forum: Bing [Bot] and 26 guests
