It is currently Thu Jul 16, 2026 12:18 am
 Post subject: balancing question
PostPosted: Fri Mar 23, 2007 12:25 am
My motor is being balance a we speek, but the shop did not ask for my cam gear. Is that normal? Do I need to have my Cam Gear and cam shaft balanced. I have a 268 cam that I got from clifford
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
PostPosted: Fri Mar 23, 2007 9:34 am
No they do not normally balance those. It is just the reciprocating assembly that gets balanced. They will need your balancer and flywheel though. They should need one set of rings and one rod bearing set as well. If they don't, they are estimating those weights. To do it right on an internally balanced engine the balancer and flywheel should be balanced separately from the crank. That way they can be replaced later it needed without upsetting the balance.
PostPosted: Fri Mar 23, 2007 9:35 am
PostPosted: Sun Mar 25, 2007 2:49 pm
thanks. the shop has all the parts for the motor but the cam and cam gear
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
Users browsing this forum: Amazon [Bot] and 9 guests
