It is currently Sat Jul 18, 2026 12:28 am
 Post subject: squeaky PCV valve
PostPosted: Tue Mar 20, 2007 11:42 am
So on my slant I have had 2 new PCV valves in the past month. They are both brand new FRAM brand plastic ones, and they both squeak!! I would like to try different ones, but I don't know the criteria for selecting a PCV valve. My slant is a super six with a 350CFM Holley. What kind of PCV valve can I get that doesn't squeak? I tried one off my friend's 340 that is a FRAM metal one (mostly metal) and it worked fine, but I was afraid to buy one incase it pulls too much or too little vacuum.
Ideas?
PostPosted: Tue Mar 20, 2007 12:14 pm
Fram's stuff (all of it) is generally of poor quality.
Try a NAPA Echlin 2-9207 (you can also get a new grommet at NAPA, Balkamp number 6301051 ). That's a plastic-body valve, the same style Chrysler used from '71 to date, but I've never had one whistle or squeak for me. If you want a metal-housing valve, use ACDelco # CV761C. You can get the CV761C and a new Dorman grommet 42064 (or Airtex 2P1007) at RockAuto. Check your PCV hose and carb base gasket as well as your crankcase breather cap and its grommet to make sure none of those is the source of the squeak via a vacuum leak.
PostPosted: Tue Mar 20, 2007 12:46 pm
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
If your PCV valve is squeaking that means that you don't have enough oil blowby to lubricate it. You can solve the problem with a cheap chrome valve cover w/o baffles from Ebay. Usually for around $20.
Good luck,
Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
PostPosted: Tue Mar 20, 2007 12:58 pm
Either you are teasing him, or you are giving completely rotten advice. Neither is helpful, nice, or productive, so kindly please cut it out now, thanks. :-)
PostPosted: Wed Mar 21, 2007 5:42 am
That was a joke, son. Sorry it wasn't recognized as such.
:oops:
Joe Hoppe
PostPosted: Fri Mar 23, 2007 12:31 pm
Good luck,
Joe
I don't care who you are, that right there is funny!
:P
Back to the original problem- Since this "squeak" (whistle maybe?) is happeneing with two valves, maybe its a split PCV hose or something outside the valve itself.
PostPosted: Fri Mar 23, 2007 3:28 pm
Sorry I overreacted—didn't see or infer a :-) and thought probably neither would the guy asking for help.
Users browsing this forum: Amazon [Bot] and 17 guests
