It is currently Fri May 15, 2026 1:12 pm
 Post subject: Case Spreader
PostPosted: Tue Apr 03, 2007 9:44 am
I have a 7.25 rear axle with LBP form a mid 70s A-body car. I also have a sure grip which I want to install in that housing along with a set of 3.23 gears. The FSM show a tool used to spread the case to facilitate removal and reinstalation of the carrier and ring gear but I don't happen to have one of these lying around. Is there an alternative method for performing this task?
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Tue Apr 03, 2007 10:15 am
My 7.25 gear swaps had me prying the gears into the case with a big screw driver. It would take you longer to setup the spreader than it does to pry it in.
PostPosted: Tue Apr 03, 2007 10:27 am
I had the same issues with a Dana 60. It took lots longer to do with a spreader. :shock:
PostPosted: Tue Apr 03, 2007 11:06 am
Next question then. What do I need besides bearings and shims? Should I just buy a complete install kit?
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Tue Apr 03, 2007 9:52 pm
It's always best to have the complete kit. It may cost a little more, but it will save time in the long run. :shock:
PostPosted: Wed Apr 04, 2007 5:03 am
I was afraid you were going to $ay that. <$igh>. Oh well, I'm not in this to save money. :roll:
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
