It is currently Sat Nov 28, 2026 3:15 pm
PostPosted: Sat Apr 28, 2007 2:55 pm
Hi this is my first post here .I have a 1981 Dodge D150 , one of the nipples on the vacuum tree was broken off ,and stupid me decided to take it off with a wrench. You know what happened . What is the easiest way to get it out of the threads of the intake.
Thanks
Dave
PostPosted: Sat Apr 28, 2007 3:06 pm
With a straight-flute extractor. This is one of those conical tools with sharpened ridges running along its outside length. Tap it into the broken-off vacuum tree until it's firmly wedged, apply Kroil to the threads, then carefully back the vacuum tree out of the manifold.
Example here
PostPosted: Sat Apr 28, 2007 4:36 pm
Thanks Dan,for the quick response and the pics of the tool.
PostPosted: Sat Apr 28, 2007 6:41 pm
I have one more question I forgot to ask.
Where can I get , or what can i use to replace the tree ?
Thanks
Dave
PostPosted: Sat Apr 28, 2007 6:58 pm
That depends...how many vacuum lines do you have that need to see manifold vacuum?
PostPosted: Sat Apr 28, 2007 7:03 pm
it had three lines going to it
PostPosted: Sat Apr 28, 2007 8:12 pm
H'mm. OK, so then you'll probably need to install another tree. Got any decent wrecking yards near you?
PostPosted: Sat Apr 28, 2007 8:15 pm
Car Model: 1963 Plymouth Valiant
Those little extractors are golden. I've impressed several buddies of mine with how well they get broken studs out of stuff! (most of the time)
PostPosted: Sun Apr 29, 2007 5:44 am
Thats where I thought I was going to have to go (junkyard).
I didn't know if there was something else people used instead of that.
like other vehicles trees, or something from the hardware store.
I read in the archives here that, the older vans had metal trees.
Thanks for all of the replies , I figured , check with the experts first ,before wasting alot of time. The truck was my Grandfathers ,and I am going to start doing some repairs a little at a time . Which the first is the exhaust manifold gasket , thus my first dilemma.Thats when I discovered the tree.
Thanks
Dave
PostPosted: Sun Apr 29, 2007 7:14 am
In a pinch you could use a couple of vacuum tees which should be available from any parts store.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Apr 29, 2007 7:55 am
Looks like you can still get a brand-new tree from the Chrysler dealer, p/n 4458 186.
PostPosted: Sun Apr 29, 2007 11:48 am
Thanks I'll have to swing by my dodge dealership. I tried to look online
to find if they still sell them. Every site I went on had nothing about it , because most older parts are not in inventory anymore , mainly the parts I need . well thanks again Dan , This is a great site , I've been searching it for a while ,and it is very helpful. and has very helpful people. Ill shut up now and watch the race.
Thanks
Dave
Users browsing this forum: Ahrefs [Bot] and 4 guests
