It is currently Tue Apr 28, 2026 1:29 pm
 Post subject: Holley 600
PostPosted: Wed May 16, 2007 9:29 pm
I was wondering what colour spring to use for the secondary diaphragm on my holley Yellow or Purple? It comes with the black but thats going to be to stiff, anyone have any experience with this?
Thanks TF
Even in moderation i am excessive!
PostPosted: Fri May 18, 2007 1:04 am
bought the spring kit and changed the black spring to a white spring, may be too light but will find out on the initial run! Would rather learn on my own anyways :twisted: !
Thanks TF
PostPosted: Fri May 18, 2007 3:52 am
I have found the yellow one to work best in my 465 Holley.
PostPosted: Fri May 18, 2007 4:56 am
hi, use the tall yellow. there is also a short yellow but the tall one works better. ron
PostPosted: Fri May 18, 2007 3:39 pm
Besides the spring, you can tune the secondaries with kill bleed sizes.
Although the spring and kill bleed affect each other, basically, the springs control opening rate of the secondaries and the bleed controlls the RPM when opening starts.
So, if the opening rate is OK and you need for them to kick in at a lower RPM, reduce the bleed hole size.
Slant Cecil
PostPosted: Fri May 18, 2007 8:56 pm
Thanks for the advise,I'll be running it this weekend and see if the engine wants something different. I have already jetted it down close to what it should be hopefully this will save some head scratching. I am going to try to get the secondarys to open around 2800 rpm but may have to change that depending on how it runs. Thanks again for the help as this will be a trial and error effort!
TF
 Post subject: Got it on and running!
PostPosted: Sat May 19, 2007 5:08 pm
Fired it up today and ran it around the block and was quite suprized with the power difference from the 1 bbl. It has a small bog at about 2000 rpm but at wide open throttle on a gentle curve in second gear at 3200 rpm the rearend tryed to swap with the front! I got out of it and saved it before i backed into someones yard, but what the h#** this is a slant six :shock: ! looks like this will be more fun than i had anticipated :twisted: . Some minor tunning should have it running very well thanks for the help again it has saved me allot of time!
Users browsing this forum: Dart270 and 1 guest
