It is currently Thu May 21, 2026 5:04 am
PostPosted: Sat Mar 24, 2007 7:12 pm
On my 64' Valiant there is a rectangular box that connects the column to the steering box. this is usually packed with grease and then there is a rubber seal to keep all the grease in and a big metal clip that holds the whole thing in place. my question is does anyone know where to get the seal? It being the weekend my normal parts sources are closed. is this a hard to find item? there is also a rubber seal that goes around the column sleeve and the column shaft that I would like to find.any help with this would be much appreciated.
PostPosted: Mon Mar 26, 2007 4:44 am
Car Model: 1967 Dodge Dart 270
www.steerandgear.com/ has the boot that you are talking about. I use them on my Dart and Duster. The boot slides over the steering shaft, fill the coupling with grease and slide the other end over the coupling and your done. They eliminate the factory rubber seal and the metal ring. Makes for a nice clean install without grease leaking out all over the place. Cost around $15. Hopes this helps.
PostPosted: Mon Mar 26, 2007 5:25 am
i'm not sure of the years but the factory part # is 4443436AC for the one on my 74 swinger and this is a kit for the whole rebuild lists for $10.50 and readily available next day from any mopar dealer (kit includes:shoes, spring, seal, retainer, and roll pin)
PostPosted: Mon Mar 26, 2007 8:26 pm
just what I was looking for. will call tomorrow. hopefully it wont take to long to get. I want to get my car back on the road!!!
PostPosted: Tue Mar 27, 2007 4:48 am
Double check this. I bought one of the coupler rebuild kits, and it would not fit my 65 Valiant. I understand there is an early (small) coupler, and the later (large) coupler. I'm not sure what year they changed. The large coupler kit is available, I have not found a small coupler kit (have not looked real hard).
PostPosted: Tue Mar 27, 2007 8:01 am
my books only go back to 72 so I cant check back to 65 but on dealer connect it states the model year in is 1951 and the model year out is 1996 so it looks like it might work but I do not have a book that goes back that far
PostPosted: Tue Mar 27, 2007 9:34 am
That's correct. 1965 was the first year for the large coupler.
PostPosted: Tue Mar 27, 2007 10:18 am
Dan are you sure it wasn't 67 for the large coupler? I have three 66 "A" bodies and they all have the small coupler. My 69 has the large. I have the 66 parts manual on disc, and also the 68-69. The 66 part number is different then the 69 part number. Also the 66 picture shows 2 springs inside the coupler, while the 69 shows a sinle "bridge" spring.
PS: neither of these manuals call out a "complete" coupler, just the individual parts.
PostPosted: Tue Mar 27, 2007 11:11 am
if you get me a few of the part #'s you found id bet mopar superseded it into a kit
PostPosted: Tue Mar 27, 2007 3:55 pm
Small coupler=1966 parts book
Body 2768202
spring 2530540
shoe 2530539
seal 2800741
cover 2530538
Large coupler=1969 parts book
Body 2996856
spring 2925492
shoe 2800738
seal 2800741
cover 2530538
PostPosted: Tue Mar 27, 2007 5:05 pm
Pretty sure, yeah...my '62 has the small coupler, my '65 had the large; it's possible there were more than two designs for this coupler.
PostPosted: Wed Mar 28, 2007 5:05 am
2530540 spring their is one dealer still showing this part it is unpriced in the mopar master
RICHARDS AUTO SALES INC MC CONNELLSBURG PA USA Phone: (717)-485-3113 / (717)-485-3113
2530539 shoe is located at
HAHN & SONS INC LEHIGHTON PA USA Phone: (610)-377-2642
YOUNG'S MOTORS INC MILTON NY USA Phone: (845)-795-2111
DIXIE MOTOR CO WILLIAMSTON NC USA Phone: (252)-792-2156 / (252)-792-2157
2800741 seal is located at
JONES CHRYSLER-DODGE INC TIFTON GA USA Phone: (229)-382-0440
2530538 their is about 100 dealers across the us with them
but the cover and seal both supersede to the kit mentioned earlier
PostPosted: Wed May 30, 2007 3:32 pm
Does this help?
http://www.1962to1965mopar.ornocar.org/ ... upler.html
63 Signet / 10 inch front drums / weber 2bbl / HEI / 2.76 rear end
PostPosted: Thu May 31, 2007 5:49 am
Does this help?
Yes, Thanks
PostPosted: Fri Jun 01, 2007 10:54 am
whatever steerandgear sent me was correct for my car. dont know if its big or small.
