It is currently Wed May 20, 2026 11:01 pm
 Post subject: where's reverse?
PostPosted: Wed May 30, 2007 6:22 am
I just installed an A-833 4-speed with (used) Hurst shifter. I'm having trouble locating reverse with the shifter. Should one push down and then up to the right, down and down to the right? Don't know. Thanks for any hints.
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
PostPosted: Wed May 30, 2007 7:13 am
On mine, reverse is hard left from neutral, then forward, just to the left of first gear.
66 Valiant, 225.
84 Van, 225.
71 Maxi-Van, 318
60 Valiant wagon, 225
87 Maxi-Van, 318 4spd
PostPosted: Wed May 30, 2007 9:44 am
aaaah, left. Lemme give that a try. thanks a bunch rlklaus. :idea:
PostPosted: Sun Jun 03, 2007 6:44 am
Before entering first or reverse? Drop it into second to stop the gears from turning. It is easier on the syncho's. Reverse might not have synchro's. My 3 speed doesn't have them in first either.
:shock:
