It is currently Tue Nov 24, 2026 8:35 pm
PostPosted: Sun Jun 03, 2007 7:26 pm
Has anyone used or recommends one to bump the throttle when the A/C compressor comes on? I have an aftermarket 4 barrel throttle cable deal. (I can't remember what it called)
When the A/C comes on it drops the rpm about 150 rpm.
http://tinyurl.com/2wg98v
Last edited by Bren67Cuda904 on Mon Jun 04, 2007 2:46 am, edited 2 times in total.
PostPosted: Sun Jun 03, 2007 8:22 pm
Throttle kicker solenoids can indeed keep the idle speed constant (or even speed it up a little) when the A/C engages. They came into use as original equipment on slant-6s only late in the game, the first one was in '76, and it was a vacuum-operated AIS kicker rather than a solenoid. If there's a solenoid readily available and easily adaptible to your carb, go for it. Wiring it up is easy: Find the wire that goes from your interior A/C control to the compressor clutch, connect it to terminal number 86 of a standard dual-output NO relay, ground terminal number 85, connect terminal 30 with a fused 14ga wire to +12v, connect one terminal 87 to the kicker solenoid and the other terminal 87 to the compressor clutch.
Nice lookin' engine, BTW.
PostPosted: Mon Jun 04, 2007 2:54 am
Thanks
Those kicker solenoids need a relay? They pull that much power?
PostPosted: Mon Jun 04, 2007 6:39 am
Look for a GM anti-dieseling solenoid. They used them in the 70's on lots of models. I do not believe they were relayed. :shock:
PostPosted: Mon Jun 04, 2007 8:00 am
The solenoid itself doesn't need a relay, but the compressor clutch draws a great deal of power (cooked control switches are common) and using a relay to control both the solenoid and the clutch takes the workload off the control switch (the original workload and the new additional load the solenoid would've added).
Users browsing this forum: Google [Bot] and 9 guests
