It is currently Wed Nov 25, 2026 10:12 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Tue Jun 12, 2007 5:05 pm
looks like a 74-76 is the peak of options. drool tube, hardened valve seats, and revised chamber.
'99 T/A
plannin out a 64-66 turbo SL6 barracuda
PostPosted: Tue Jun 12, 2007 5:11 pm
thats something i meant to ask! i've heard around that older engines with softer valve seats NEED lead or a lead substitute to protect those parts, is this true of the slant6s?
In progress: '64 Dart Vert
PostPosted: Tue Jun 12, 2007 5:33 pm
Total bullshyt.
As far as porting goes, you want the ports left with a slightly rough finish for mixture distribution. Too smooth a port will cause fuel puddling. Polishing the exhaust side is a waste too. They will carbon over in a short time anyway.
PostPosted: Tue Jun 12, 2007 6:10 pm
thanks again, so running unleaded in a '64 225 wont cause any problems? i just want to be 100% sure. i always sort of thought the reasoning was bull as well, but i heard it soo much that i thought it to be true.
PostPosted: Wed Jun 13, 2007 8:27 am
Hi Bitter,
And I thought I was bitter. I got a lot of info from this article:
http://www.sa-motorsports.com/diyport.aspx
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
PostPosted: Wed Jun 13, 2007 4:08 pm
Hi Bitter,
thanks, i bookmarked it and i'll pour over it later but it looks pretty good and thorough.
