It is currently Fri May 29, 2026 3:02 pm
PostPosted: Mon Jun 04, 2007 11:56 am
Mopar bracket drag racing at Infineon (Sears Point) on Saturday, 6/16/07. I don't know anything about this event, but I plan to go and clock my Dart (if I get it finished in time). Hopefully I won't be the only /6 there. Here's the Infineon dragstrip schedule:
http://www.infineonraceway.com/schedule ... Fschedule/
Cheers,
Steve
1966 Dodge Dart GT
PostPosted: Mon Jun 04, 2007 12:29 pm
Yes, I am also thinking about running a car at this event.
I went last year and it was a good event but I only lasted 2 rounds in the "Street" bracket. :cry:
PostPosted: Thu Jun 14, 2007 10:05 pm
I have the NOS bottles filled and checked the 62 Lancer over, all is ready to "rumble" so I will be out there as early as possible on Saturday.
Look for a run-down looking green Lancer with a frog painted on the roof.
PostPosted: Fri Jun 15, 2007 12:28 pm
Unfortunately I twisted a spark plug off in the cyl head last night, so I'm a maybe for the Mopar race tomorrow. Must have been a defective plug, I was only torquing lightly. Will pick up a big easy-out tonight and hopefully get repaired for tomorrow, ready to run if not rumble.
Go get 'em, Doug!
Steve
1966 Dodge Dart GT
PostPosted: Mon Jun 18, 2007 6:16 am
How did you guys do over the weekend. I heard Glen Terry was going to race also....Update appreciated..Sorry about your head Steve...You will have lots of time to fix and see you at Redding on August 25-26? Maybe you can "caravan " with Doug and Allen? See you at Redding...
PostPosted: Mon Jun 18, 2007 9:43 am
We had fun but I had to do a bunch of work to the Lancer to fix an ignition miss, the car did not run clean until the first round of eliminations... then I broke-out.
Glen was still working his way thru the Sportsman class when I left the track at around 2:00.
PostPosted: Mon Jun 18, 2007 11:55 pm
Fortunately the remainder of the spark plug eased-out using an easy-out. Car still needs a bit more attention, a few more adjustments before putting it on the dragstrip. It's been 3 years completely rebuilding it, so I'd like to get some reasonable times when I finally run it. That's my excuse, anyway.
I've got Redding on the calendar - certainly plenty of time to get the bugs worked out and run a few Wednesday night practice sessions at Infineon.
Here's a couple pics of that broken plug, BTW:
Image Image
Steve
1966 Dodge Dart GT
Super Six intake, Weber carb, Comp 264 cam, head ported and milled .030, Dutra exhaust, 3.21 Sure-Grip rear, disc brakes, etc.
