It is currently Tue Jun 16, 2026 1:30 am
 Post subject: Distributor question
PostPosted: Tue Jun 19, 2007 9:20 am
I've just swapped in a mid seventies /6 into my 67 A-body. I notice there is a bolt holding the adjustment plate underneath the distributor that was a little loose, while the hold down bolt goes through a hole in what I am calling the adjustment plate, instead of through a slot as in the earlier model. Should I leave the bolt a little loose, and tighten by means of the hold down bolt? In the dark- once again.
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
PostPosted: Tue Jun 19, 2007 9:48 am
Is the distributor from your old engine, or the 'new' one. Are you talking about the bolt that is on the underside of the distributor, and accesible only when you take it out?
Sam
PostPosted: Tue Jun 19, 2007 9:59 am
The distributer is from the new engine and bolt is on the underside as you describe. It bolts through a slot.
PostPosted: Tue Jun 19, 2007 10:43 am
It allows for more adjustment. It does need to be tight before install.
Excuse me, does this smell like chloroform to you?
PostPosted: Tue Jun 19, 2007 11:31 am
Thanks, tight sounds about right. I pretty much tightened it where it was in the slot. The distributer was just rebuilt, I guess they forgot to tighten the bolt.
Users browsing this forum: Plymouth_Ruster and 2 guests
